Consistent look with JideButton and JideSplitButton
Postby judodan » Mon Sep 17, 2012 12:31 pm
I've got a UI where I am keeping a list of fields to sort by. I use a JideSplitButton to allow the user to add a field to the list (the fields are in the menu) and a JideButton to allow them to remove from the list.
Even though I'm configuring them the same way, they come up looking different (functionality is fine). My code is here:
       jRemoveSortButton.setText("Remove Sort");
       jRemoveSortButton.setButtonStyle(JideButton.TOOLBOX_STYLE);
       jRemoveSortButton.addActionListener(new ActionListener() {
           public void actionPerformed(ActionEvent evt) {
               removeSort();
       jAddSortButton.setText("Add Sort...");
       jAddSortButton.setAlwaysDropdown(true);
       jAddSortButton.setButtonStyle(JideSplitButton.TOOLBOX_STYLE);
       for (String field : FIELDS) {
           jAddSortButton.add(new AbstractAction(field) {
                   addSort(evt);
and they come out looking like this:
Button Image
Any suggestions appreciated. Thanks!
judodan
Re: Consistent look with JideButton and JideSplitButton
Postby JIDE Support » Mon Sep 17, 2012 2:35 pm
Can you please share with us a stand-alone test case? I tried in Plastic, Metal L&F but could not observe the similar behavior. It looks like that the button is already pressed down when the application is started up.
Postby judodan » Mon Sep 17, 2012 3:20 pm
Same problem with a simple example. Here is the simple example code:
package example;
import javax.swing.AbstractAction;
import javax.swing.GroupLayout;
import com.jidesoft.swing.JideButton;
import com.jidesoft.swing.JideSplitButton;
public class ButtonSample extends javax.swing.JFrame {
    public ButtonSample() {
        initComponents();
    private void initComponents() {
        jButton1 = new JideButton();
        jButton2 = new JideSplitButton();
        setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
        jButton1.setText("Button");
        jButton1.setButtonStyle(JideButton.TOOLBOX_STYLE);
        jButton1.addActionListener(new ActionListener() {
                // some code
        jButton2.setText("Split Button...");
        jButton2.setAlwaysDropdown(true);
        jButton2.setButtonStyle(JideSplitButton.TOOLBOX_STYLE);
        jButton2.add(new AbstractAction("Menu Item 1") {
                // handler code...
        jButton2.add(new AbstractAction("Menu Item 2") {
                // handler code...
        GroupLayout layout = new GroupLayout(getContentPane());
        getContentPane().setLayout(layout);
        layout.setHorizontalGroup(
            layout.createParallelGroup(GroupLayout.Alignment.LEADING)
            .addGroup(layout.createSequentialGroup()
                .addContainerGap()
                .addComponent(jButton1)
                .addGap(18, 18, 18)
                .addComponent(jButton2)
                .addContainerGap(182, Short.MAX_VALUE))
        layout.setVerticalGroup(
                .addGap(45, 45, 45)
                .addGroup(layout.createParallelGroup(GroupLayout.Alignment.BASELINE)
                    .addComponent(jButton2))
                .addContainerGap(226, Short.MAX_VALUE))
        pack();
    public static void main(String args[]) {
            for (javax.swing.UIManager.LookAndFeelInfo info : javax.swing.UIManager.getInstalledLookAndFeels()) {
                if ("Nimbus".equals(info.getName())) {
                    javax.swing.UIManager.setLookAndFeel(info.getClassName());
                    break;
        } catch (ClassNotFoundException ex) {
            java.util.logging.Logger.getLogger(ButtonSample.class.getName()).log(java.util.logging.Level.SEVERE, null, ex);
        } catch (InstantiationException ex) {
        } catch (IllegalAccessException ex) {
        } catch (javax.swing.UnsupportedLookAndFeelException ex) {
        java.awt.EventQueue.invokeLater(new Runnable() {
            public void run() {
                new ButtonSample().setVisible(true);
    private JideButton jButton1;
    private JideSplitButton jButton2;
judodan
Postby JIDE Support » Mon Sep 17, 2012 4:01 pm
I believe the different looking is caused by the layout and the focus. The modified test case shows the same appearance for those two kinds of buttons.
        initComponents();
                // some code
                // handler code...
                // handler code...
        getContentPane().setLayout(new GridLayout(1, 0));
        getContentPane().add(jButton1);
        getContentPane().add(jButton2);
            public void run() {
                jButton2.requestFocus();
        pack();
                    break;
            public void run() {
Postby judodan » Tue Sep 18, 2012 7:38 am
OK, so the suggested layout works better for me too. The problem, though, is that my UI is (of course) much more complicated. I'm sure you can guess from my code that it was generated with NetBeans (I wouldn't hand-code something that complicated :) ).
Is there something to look for/change in my more complex UI? (should I try to post it here?)
Edit:
As a followup, I changed the L&F to be the stock Metal L&F and the buttons look the same now. Seems to be a quirk of the Nimbus theme.
judodan
Postby JIDE Support » Tue Sep 18, 2012 10:14 am
Yep, this is caused by the combination of L&F, layout and focus. You might have to switch the L&F if you don't like to write those UI codes directly.
Postby Walter Laan » Wed Sep 19, 2012 12:15 am
You can try to call setFocusable(false); on the split button (but cannot use the keyboard then to activate it, so probably want to add a shortcut for it)
Walter Laan
