Suppressing selection events from TableSearchable
Postby teknosoul » Sun Sep 16, 2012 7:34 am
Using JIDE 3.4.5, is there any way to suppress / prevent a TableSearchable and shrink support from firing selection events? I find that it fires a lot of selection events when changing the search string. The following seems to happen and I get 3 valueChanged events on the selection model before a searchable event.
evt1 - TableSearchable.addTableSelection eventually calls JideTable.changeSelection which eventually fires a DefaultListSelectionModel.fireValueChanged
evt2 - TableSearchable.addTableSelection calls JideTable.clearSelection which eventually fires the DefaultListSelectionModel.fireValueChanged
evt3 - same flow as evt1
for all events, evt.getValueIsAdjusting() returns false.
Then I get a Searchable_change event followed by another valueChangedEvent triggered by the TableShrinkSearchableSupport.applyFilter and finally a Searchable_match
I'm not sure what the first 3 events are for, but if we do anything somewhat expensive in the selection events, these pose a problem. So basically, is there a way for searchable to just do the filtering and not selection?
teknosoul
Re: Suppressing selection events from TableSearchable
Postby JIDE Support » Mon Sep 17, 2012 1:23 pm
Per my testing, two selection events instead of three are detected on searching. Due to the fact that the selected row is always the first row on searching, I'm afraid that we have to clear selection first then add the selection for row 0 later to notify the listener that the selected content actually changed although the selected row didn't.
Please correct me if you still observe 3 events.
