Disabling sorting when filter is applied or removed
Postby niteen22 » Tue Sep 11, 2012 4:07 am
I am using FilterableTableModel (which is wrapped by SortableTableModel) and applying and removing filters based on button click. I am fetching filterablemodel properly when filter need to be applied or removed.
model = new SortableTableModel(filterableModelInstance);
IFilterableTableModel filterModel=(IFilterableTableModel) TableModelWrapperUtils
.getActualTableModel(model ,FilterableTreeTableModel.class);
My logic is when I remove filters certain rows are displayed at the end of table. However if one of the column is in sorted state, table is refreshed and sorted again after removing the filter hence those rows are placed based on sorting state. Is there any way to avoid table sorting when filter is applied or removed to the model. I still want to enable sorting when columns are explicitly clicked
Nitin
niteen22
Re: Disabling sorting when filter is applied or removed
Postby JIDE Support » Tue Sep 11, 2012 9:04 am
If you have already modified the FilterableTableModel's logic to display the new rows in the end of the table after removing filter, please invoke SortableTableModel#setSortingPaused() to avoid the SortableTableModel to sort these rows. In this case, clicking the table header could still sort the column.
Postby niteen22 » Wed Sep 12, 2012 4:42 am
Thanks !! I will try it
niteen22
Users browsing this forum: No registered users and 70 guests
