RTL issues in some components
Postby Reyada Wolak » Wed Aug 08, 2012 3:27 am
Using jide_demo,
- the orientation of the label (and icons) of JideSplitButton in RTL is not reversed. it is correctly handled by JideButton but not JideSplitButton.
- the text/numbers inside SimpleScrollPane cells are not reversed in RTL. it is actually the case for all components with tables/cells.
- AutoCompletionComboBox popup menu is not reversed (the text). for example it is correctly handled by OverlayComboBox
Reyada Wolak
Re: RTL issues in some components
Postby JIDE Support » Wed Aug 08, 2012 4:53 pm
Thanks for the bug report. Will fix the issues on JideSplitButton and AutoCompletionComboBox in next regular release. Regarding of SimpleScrollPane, it will work if a JideTable was used instead of JTable.
Postby JIDE Support » Fri Aug 10, 2012 2:12 pm
Regarding of AutoCompletionComboBox, I am afraid you have to do it yourself.
AutoCompletionComboBox extends JComboBox directly. Hence ComboBoxEditor was used when it is set to be editable. And ComboBoxEditor did not support right-to-left orientation. We recommend to use ListExComboBox with an AutoCompletion installed. A demo is posted below FYI.
 * @(#)AutoCompletionDemo.java 6/24/2005
 * Copyright 2002 - 2005 JIDE Software Inc. All rights reserved.
import com.jidesoft.combobox.ExComboBox;
import com.jidesoft.combobox.ListExComboBox;
import com.jidesoft.combobox.PopupPanel;
import com.jidesoft.plaf.basic.ExComboBoxEditor;
import com.jidesoft.swing.*;
import com.sun.java.swing.plaf.windows.WindowsComboBoxUI;
import java.util.Arrays;
import java.util.List;
 * Demoed Component: {@link com.jidesoft.swing.AutoCompletion}, {@link com.jidesoft.swing.AutoCompletionComboBox}. <br>
 * Required jar files: jide-common.jar, jide-grids.jar <br> Required L&F: Jide L&F extension required
public class AutoCompletionDemo {
    private static final long serialVersionUID = -3703831246278663243L;
    protected String[] _fontNames;
    protected List<String> _fontList;
    public AutoCompletionDemo() {
    public String getName() {
        return "AutoCompletion Demo";
        _fontNames = DemoData.getFontNames();
        _fontList = Arrays.asList(_fontNames);
        JPanel panel1 = createPanel1();
        JPanel panel2 = createPanel2();
        JPanel panel = new JPanel(new BorderLayout(6, 6));
        panel.add(panel1, BorderLayout.BEFORE_FIRST_LINE);
        panel.add(panel2);
        return panel;
    private JPanel createPanel1() {
        JPanel panel = new JPanel();
        panel.setLayout(new JideBoxLayout(panel, JideBoxLayout.Y_AXIS));
        panel.setBorder(BorderFactory.createCompoundBorder(new JideTitledBorder(new PartialEtchedBorder(PartialEtchedBorder.LOWERED, PartialSide.NORTH), "AutoCompletion combo box and text field", JideTitledBorder.LEADING, JideTitledBorder.ABOVE_TOP),
                BorderFactory.createEmptyBorder(0, 0, 0, 0)));
        ExComboBox autoCompletionComboBox = new ListExComboBox(_fontNames, String.class);
        autoCompletionComboBox.setName("AutoCompletion JComboBox (Strict)");
        autoCompletionComboBox.setToolTipText("AutoCompletion JComboBox (Strict)");
        panel.add(new JLabel("AutoCompletion JComboBox (Strict)"));
        panel.add(Box.createVerticalStrut(3), JideBoxLayout.FIX);
        panel.add(autoCompletionComboBox);
        panel.add(Box.createVerticalStrut(12), JideBoxLayout.FIX);
        ListExComboBox autoCompletionComboBoxNotStrict = new ListExComboBox(_fontNames, String.class);
        autoCompletionComboBoxNotStrict.setEditable(true);
        final JList fontNameList = new JList(_fontNames);
        new AutoCompletion((JTextField)(autoCompletionComboBoxNotStrict.getEditor().getEditorComponent()), new ListSearchable(fontNameList));
        autoCompletionComboBoxNotStrict.setName("AutoCompletion JComboBox (Not strict)");
        autoCompletionComboBoxNotStrict.setToolTipText("AutoCompletion JComboBox (Not strict)");
        panel.add(new JLabel("AutoCompletion JComboBox (Not strict)"));
        panel.add(autoCompletionComboBoxNotStrict);
        // create tree combobox
        final JTextField textField = new JTextField();
        textField.setName("AutoCompletion JTextField with a hidden data");
        SelectAllUtils.install(textField);
        new AutoCompletion(textField, _fontList);
        panel.add(new JLabel("AutoCompletion JTextField with a hidden data"));
        panel.add(textField);
        return panel;
    private JPanel createPanel2() {
        panel.setBorder(BorderFactory.createCompoundBorder(new JideTitledBorder(new PartialEtchedBorder(PartialEtchedBorder.LOWERED, PartialSide.NORTH), "AutoCompletion with list and tree", JideTitledBorder.LEADING, JideTitledBorder.ABOVE_TOP),
        final JTextField treeTextField = new JTextField();
        treeTextField.setName("AutoCompletion JTextField with JTree");
        SelectAllUtils.install(treeTextField);
        final JTree tree = new JTree();
        tree.setVisibleRowCount(10);
        final TreeSearchable searchable = new TreeSearchable(tree);
        searchable.setRecursive(true);
        new AutoCompletion(treeTextField, searchable);
        panel.add(new JLabel("AutoCompletion JTextField with JTree"));
        panel.add(treeTextField);
        panel.add(Box.createVerticalStrut(2), JideBoxLayout.FIX);
        panel.add(new JScrollPane(tree));
        // create font name combobox
        final JTextField fontNameTextField = new JTextField();
        fontNameTextField.setName("AutoCompletion JTextField with JList");
        SelectAllUtils.install(fontNameTextField);
        fontNameList.setVisibleRowCount(10);
        new AutoCompletion(fontNameTextField, new ListSearchable(fontNameList));
        panel.add(new JLabel("AutoCompletion JTextField with JList"));
        panel.add(fontNameTextField);
        panel.add(new JScrollPane(fontNameList));
        return panel;
            public void run() {
                AutoCompletionDemo demo = new AutoCompletionDemo();
                JFrame frame = new JFrame();
                frame.setDefaultCloseOperation(WindowConstants.DISPOSE_ON_CLOSE);
                frame.getContentPane().add(demo.getDemoPanel());
                frame.pack();
                JideSwingUtilities.toggleRTLnLTR(frame);
                JideSwingUtilities.invalidateRecursively(frame);
Postby JIDE Support » Mon Aug 20, 2012 6:15 pm
Just so you know, this is fixed in 3.4.5 just released.
