CheckBoxTree-addTreeSelectionListener is not working
Postby mandar.j » Fri Jul 27, 2012 6:28 am
I am trying to use CheckBoxTree to display a tree with checkbox. In that, when I try to add a listener to the items in CheckBoxTree, it works(event gets fired) only when I click on a tree node, but it doesn't work when I click a checkbox. Do we need to write separate listeners for both checkbox and tree node? I could only see "addTreeSelectionListener " with "valueChanged(TreeSelectionEvent)".
Any help would be appreciated.
Mandar
mandar.j
Re: CheckBoxTree-addTreeSelectionListener is not working
Postby JIDE Support » Fri Jul 27, 2012 9:17 am
Please invoke yourCheckBoxTree.getCheckBoxTreeSelectionModel().addTreeSelectionListener() to add the selection listener of the check box. As you can see from the UI, one node could be checked without selecting. Hence, two separated listeners are in use.
Postby mandar.j » Fri Jul 27, 2012 10:59 am
This also worked very well... Thanks a lot again.
Mandar
mandar.j
