Set tooltips JideTabbedPane Buttons
Postby eramirezj » Thu Jul 05, 2012 3:27 pm
I need to customize the tooltips of the buttons that are created in a JideTabbedPane component, specifically
these components are setShowTabButtons(true) unique and only visible do, thanks.
View to buttons is:
http://s2.subirimagenes.com/otros/previo/thump_7821404duda.jpg
eramirezj
Re: Set tooltips JideTabbedPane Buttons
Postby JIDE Support » Thu Jul 05, 2012 4:31 pm
Please override JideTabbedPane#getResourceString() to customize the tool tips. The relevant resource keys are showed as following code fraction.
       JideTabbedPane tabbedPane = new JideTabbedPane(JideTabbedPane.TOP){
            public String getResourceString(String key) {
                if (key != null && key.equals(BasicJideTabbedPaneUI.BUTTON_NAME_SCROLL_BACKWARD)){
                    return "backward";
                else if (key != null && key.equals(BasicJideTabbedPaneUI.BUTTON_NAME_SCROLL_FORWARD)){
                    return "forward";
                else if (key != null && key.equals(BasicJideTabbedPaneUI.BUTTON_NAME_TAB_LIST)){
                    return "list";
                return super.getResourceString(key);    //To change body of overridden methods use File | Settings | File Templates.
Postby eramirezj » Fri Jul 06, 2012 8:52 am
eramirezj wrote:I need to customize the tooltips of the buttons that are created in a JideTabbedPane component, specifically
View to buttons is:
JIDE Support wrote:Please override JideTabbedPane#getResourceString() to customize the tool tips. The relevant resource keys are showed as following code fraction.
                    return "backward";
                    return "forward";
                    return "list";
Thanks for your help, greetings :wink:
eramirezj
Postby poshoklo » Fri Mar 01, 2013 2:39 pm
Hi!
And how do you change the look and feel of the first three buttons (scroll backward, scroll forward and close)?
Thanks for your help in advance!
poshoklo
Postby JIDE Support » Fri Mar 01, 2013 3:19 pm
Those three buttons are painted by drawing directly so I don't think they will change in different L&F.
