CheckBoxTree$1 not serializable
Postby wheelerej » Mon Jun 04, 2012 1:55 pm
I am new to java and learning swing while working on an internship project. I am attempting to save a CheckBoxTree when we save the current project and I am getting the following error:
java.io.NotSerializableException: com.jidesoft.swing.CheckBoxTree$1
The information I am saving contains multiple classes that hold metagenomic data in the form of a tree containing genetic sequences. All of my data classes imlement serializable and I get the above error when I try to save. My code for saving the data is:
FileOutputStream fos = new FileOutputStream(file);
ObjectOutputStream out = new ObjectOutputStream(fos);
out.writeObject(model.getProject());
out.flush();
fos.close();
out.close();
I tried to research for this error including in the forums here but I could not find any other cases of this. I apologize if this has been brought up before.
Thank you for the help
wheelerej
Re: CheckBoxTree$1 not serializable
Postby JIDE Support » Mon Jun 04, 2012 2:50 pm
Thanks for bug report. Will try to fix it in next regular release.
Postby wheelerej » Tue Jun 05, 2012 11:15 am
Thank you for the quick response. Is there any eta on when this would be fixed or anyway I can fix it from my end? I am just curious if I should be going a different route on the whole check box tree idea.
wheelerej
Postby JIDE Support » Tue Jun 05, 2012 12:01 pm
The ETA is not solid yet. Normally we have regular releases every 2 to 3 weeks. Will keep you posted when we have a release ready. I'm afraid that there is no work around available in current release.
Postby JIDE Support » Tue Jun 19, 2012 7:01 pm
Just so you know, this is fixed in 3.4.2 just released.
