by Mohan Kankalapati » Wed May 16, 2012 8:39 am
In AutoFilterTableHeader i would like to disable the drop down filter but only need the text box to accept the filter input. I have overidden AutoFilterTableHeader.customizeAutoFilterBox() as below. Could you please let me know how to disable the filter dropdown and only have the textbox as input.
AutoFilterTableHeader header = new AutoFilterTableHeader(table) {
protected void customizeAutoFilterBox(AutoFilterBox autoFilterBox) {
super.customizeAutoFilterBox(autoFilterBox);
autoFilterBox.setSearchingDelay(-1);
autoFilterBox.setS(false);
header.setAutoFilterEnabled(true);
header.setShowFilterIcon(true);
header.setAcceptTextInput(true);
header.setShowFilterName(true);
table.setTableHeader(header);
Mohan
Mohan Kankalapati
by JIDE Support » Wed May 16, 2012 9:32 am
Please give JIDE AutoFilterTableHeaderWithInputDemo a try. The method isValuePredetermined() is the answer for your request.
- Code: Select all
* @(#)AutoFilterTableHeaderWithInputDemo.java 7/19/2010
* Copyright 2002 - 2010 JIDE Software Inc. All rights reserved.
import com.jidesoft.comparator.ObjectComparatorManager;
import com.jidesoft.converter.DoubleConverter;
import com.jidesoft.converter.ObjectConverterManager;
import com.jidesoft.filter.FilterFactoryManager;
import com.jidesoft.grid.*;
import com.jidesoft.grouper.ObjectGrouperManager;
import com.jidesoft.swing.JideTitledBorder;
import com.jidesoft.swing.PartialEtchedBorder;
import com.jidesoft.swing.PartialSide;
import javax.swing.table.TableModel;
import java.text.NumberFormat;
* Demoed Component: {@link com.jidesoft.grid.AutoFilterTableHeader} <br> Required jar files: jide-common.jar,
* jide-grids.jar <br> Required L&F: any L&F
public class AutoFilterTableHeaderWithInputDemo extends AbstractDemo {
protected AutoFilterTableHeader _header;
protected FilterFactoryManager _filterManager;
private static final long serialVersionUID = -5748117718410594572L;
public AutoFilterTableHeaderWithInputDemo() {
CellEditorManager.initDefaultEditor();
CellRendererManager.initDefaultRenderer();
ObjectConverterManager.initDefaultConverter();
ObjectComparatorManager.initDefaultComparator();
DoubleConverter converter = new DoubleConverter();
NumberFormat numberInstance = NumberFormat.getNumberInstance();
numberInstance.setMinimumFractionDigits(2);
converter.setNumberFormat(numberInstance);
ObjectConverterManager.registerConverter(Double.class, converter);
ObjectConverterManager.registerConverter(Integer.class, new DemoData.SalesConverter(), DemoData.SalesConverter.CONTEXT);
ObjectGrouperManager.initDefaultGrouper();
ObjectGrouperManager.registerGrouper(Float.class, new DemoData.SalesObjectGrouper(), DemoData.SalesObjectGrouper.CONTEXT);
_filterManager = new FilterFactoryManager();
_filterManager.registerDefaultFilterFactories();
public String getName() {
return "AutoFilterTableHeader (with Input Box) Demo";
public String getProduct() {
return PRODUCT_NAME_GRIDS;
return "\n" +
"Demoed classes:\n" +
"com.jidesoft.grid.AutoFilterTableHeader";
final TableModel tableModel = DemoData.createProductReportsTableModel(true, 0);
if (tableModel == null) {
return new JLabel("Failed to read data file");
return createSortableTable(tableModel);
JPanel checkBoxPanel = new JPanel(new GridLayout(0, 1));
JCheckBox autoFilterCheckBox = new JCheckBox("Auto Filter");
autoFilterCheckBox.addItemListener(new ItemListener() {
_header.setAutoFilterEnabled(e.getStateChange() == ItemEvent.SELECTED);
autoFilterCheckBox.setSelected(_header.isAutoFilterEnabled());
checkBoxPanel.add(autoFilterCheckBox);
return checkBoxPanel;
private JPanel createSortableTable(TableModel tableModel) {
final JPanel panel = new JPanel(new BorderLayout(2, 2));
panel.setBorder(BorderFactory.createCompoundBorder(new JideTitledBorder(new PartialEtchedBorder(PartialEtchedBorder.LOWERED, PartialSide.NORTH), "AutoFilterTableHeader", JideTitledBorder.LEADING, JideTitledBorder.ABOVE_TOP),
BorderFactory.createEmptyBorder(0, 0, 0, 0)));
SortableTable sortableTable = new SortableTable(tableModel);
_header = new AutoFilterTableHeader(sortableTable) {
protected IFilterableTableModel createFilterableTableModel(TableModel model) {
return new FilterableTableModel(model) {
private static final long serialVersionUID = 7072186511643823323L;
public boolean isColumnAutoFilterable(int column) {
return column != 2;
public boolean isValuePredetermined(int column) {
return column != 3;
_header.setAutoFilterEnabled(true);
_header.setAcceptTextInput(true);
sortableTable.setTableHeader(_header);
sortableTable.setPreferredScrollableViewportSize(new Dimension(600, 500));
sortableTable.setAutoResizeMode(JideTable.AUTO_RESIZE_FILL);
TableHeaderPopupMenuInstaller installer = new TableHeaderPopupMenuInstaller(sortableTable);
installer.addTableHeaderPopupMenuCustomizer(new AutoResizePopupMenuCustomizer());
installer.addTableHeaderPopupMenuCustomizer(new TableColumnChooserPopupMenuCustomizer());
panel.add(new JScrollPane(sortableTable));
return panel;
return "G27.AutoFilterTableHeader";
public void run() {
showAsFrame(new AutoFilterTableHeaderWithInputDemo());
by Mohan Kankalapati » Wed May 16, 2012 9:53 am
I made the changes as per your suggestion, But the drop down still appears. Any other solution please?
Mohan
Mohan Kankalapati
by JIDE Support » Wed May 16, 2012 10:01 am
Please let the method return false to disable the drop down.
