by mgunn0103 » Fri Apr 27, 2012 4:47 pm
Hello JIDE Support,
I am using the SortableTable model found in the "QuickFilter Demo (Table)". What would be the best way to permanently remove filtered (not visible) records from the sortableTable? Ultimately, I would like to save the visible subset. Does JIDE provide any easy means of accomplishing this?
Marcus
mgunn0103
by JIDE Support » Fri Apr 27, 2012 4:55 pm
Please try to invoke TableModelWrapperUtils#getActualRowAt() to get the actual row lists after filtering. Then you will be able to delete all other rows in the original table model.
