Error while invoking GroupTabel.getExpansionState
Postby uriweiner » Tue Apr 24, 2012 10:44 pm
Hi.
I keep getting the following error while im invoking the getExpansionState methode:
??? Java exception occurred:
java.lang.ArrayIndexOutOfBoundsException: -1
at java.util.Vector.get(Unknown Source)
at com.jidesoft.grid.TreeTableModel.getExpansionState(Unknown Source)
[/color]
Can you hel p point me in the right direction to overcomne this issue?
uriweiner
Re: Error while invoking GroupTabel.getExpansionState
Postby JIDE Support » Wed Apr 25, 2012 10:55 am
Did you invoke DefaultGroupTableModel#getExpansionState() or TreeTableModel#getExpansionState()? Can you please share with us the full stack trace? If possible, please download a debug release so that we could see the detailed line information in the stack trace.
Postby uriweiner » Sun Apr 29, 2012 12:15 pm
I invoked DefaultGroupTableModel#getExpansionState() to get the error.
The thing is that when the user expaned the tree, insome cases i do get the mehtode output (map) and in other cases i get the reported error.
However, when i try to use the next methode (DefaultGroupTableModel#setExpansionState(map) , i expected that the tree will return to its previuse from
But nothing happands. - this is when i can obtin the map.
Am i missing something? do i need to use other methodes to get the tree back to its previuse form?
Regarding the Error, can you explain what debug do i need to download in ortder to send you the stack? can you share a link?
Uri
uriweiner
Postby JIDE Support » Mon Apr 30, 2012 10:23 am
It's hard to say where the issue is without a test case. I can't reproduce the issue with the attached test case. You could also download the debug release at http://www.jidesoft.com/evaluation/index.php so that we could see the detailed stack trace.
GroupTableDemo.java
(15.19 KiB) Downloaded 3421 times
