by jeffastorey » Wed Apr 18, 2012 4:51 am
I'm using JIDE OSS 2.10.2 and it appears the pom does not validate correctly. I get the following error messages from maven:
[WARNING] The POM for com.jidesoft:jide-oss:jar:2.10.2 is invalid, transitive dependencies (if any) will not be available: 2 problems were encountered while building the effective model for com.jidesoft:jide-oss:2.10.2
[ERROR] 'dependencies.dependency.systemPath' for aqua_ui:ui:jar must specify an absolute path but is ${basedir}/libs/ui.jar @
[ERROR] 'dependencies.dependency.systemPath' for aqua_ui:jrs:jar must specify an absolute path but is ${basedir}/libs/JavaRuntimeSupport.jar @
Can the pom be fixed?
jeffastorey
by JIDE Support » Wed Apr 18, 2012 9:36 am
Sun discontinued the maven for java.net so that maven repository on java.net is not being maintained right now. For now I suggest you download the jide-oss jar yourself from java.net and create your own maven repository for it before we find another open source maven repository for it.
by jeffastorey » Wed Apr 18, 2012 3:16 pm
Thanks, that is what I will do.
jeffastorey
