Remove Rows in JIDE - Group Tbale
Postby uriweiner » Mon Apr 16, 2012 3:25 am
I’m using jidesoft.grid.DefaultGroupTableModel class wrapping swing.table.DefaultTableModel .
Problem is When I’m trying to remove a grouped row (DefaultGroupRow ) using the method jidesoft.grid.DefaultGroupTableModel.removeRow(row index) ,
The Row is removed visually only , and still exists in the swing.table.DefaultTableModel.
When i preform the groupAndRefresh method, the deleted row is re-created in the front end.
How can I remove the grouped table row that will be removed from the swing DefaultTableModel.
Thanks in advance.
Uri W.
uriweiner
Re: Remove Rows in JIDE - Group Tbale
Postby JIDE Support » Mon Apr 16, 2012 9:00 am
Please go through all rows in the original table model and invoke DefaultTableModel#removeRow() for all matching rows that meet the criteria of the DefaultGroupRow.
Postby uriweiner » Tue Apr 17, 2012 12:25 am
Thanks for the Replay But my problem is:
how do i match the selected rows in the groupTableModle index with the Original modle rows index?
for ex. if user selected row 3 in the group table modle, how do i locate the row index in the Original modle so i will be able to delete it?
uriweiner
Postby JIDE Support » Tue Apr 17, 2012 11:42 am
Please invoke ((DefaultGroupRow) _table.getRowAt(3)).satisfies(originalModel, rowIndexInOriginalModel); to check if the row matchs the designated DefaultGroupRow.
Postby uriweiner » Wed Apr 18, 2012 12:30 am
Thanks for the answer but it doesn’t answer my question.
The Question is:
if the row selected in the Group Table is 3 (row number 3 in the group table), how do i locate the Index of this row in the Original Table model.(for example it is row 7 in the original model)
(Do i use the method : getOriginalRows(3) or do you have a different method that will allow me to match :
Selected group table row index ----> to ---- > Original table model row index.
I’m looking for a method that will behave like:
orig_index = groupTableModel.(<methode that locates orig indexes for ex. >) (3)
then I’ll get that orig_index = 7.
Thanks for your support!
Uri
uriweiner
Postby JIDE Support » Wed Apr 18, 2012 8:53 am
If the row is a DefaultGroupRow, there might be many rows in your original table model that match the DefaultGroupRow. That's why you have to loop through all your rows in the original table model to check if those rows satisfy the conditions of the DefaultGroupRow. The API you are anticipating does not exist. The pseudo code to get all row indices is posted below FYI.
List<Integer> matchingRowIndicies = new ArrayList<Integer>();
DefaultGroupRow groupRow = (DefaultGroupRow) _table.getRowAt(3);
for (int rowIndex = 0; rowIndex < originalModel.getRowCount(); rowIndex++) {
    if (groupRow.satisfies(originalModel, rowIndex)) {
        matchingRowIndicies.add(rowIndex);
Users browsing this forum: Bing [Bot] and 89 guests
