by mgunn0103 » Fri Apr 06, 2012 3:30 pm
Hello JIDE Support,
I am using the QuickFIlterPane along with a SortableTable. Is there anyway to disable or stop the sorting of the JList in the QuickFilterPane? The pane is being used to display dates. I would like to display these dates in descending order rather than ascending. Is this possible?
Marcus
mgunn0103
by JIDE Support » Fri Apr 06, 2012 5:18 pm
The values displayed in the JLists are retrieved from FilterableTableModel's getPossibleValues method. So you can create your own FilterableTableModel by overriding createFilterableTableModel, then override getPossibleValues method to add your own sorting.
by mgunn0103 » Fri Apr 27, 2012 4:43 pm
This solution worked out great! Thanks!
mgunn0103
Users browsing this forum: Bing [Bot] and 86 guests
