RowHeaderTable - show data for expanded cell in each row
Postby wolfgang » Tue Mar 27, 2012 10:30 am
Pivot table aggregated data in RowHeaderTable. With Buttons [+] or [-] you can expand or collapse rows. For example expanded cell in RowHeaderTable has very high height and screen.height is not enough to show all and user has scrolled up away top line row, so there are no data to see in middle of screen of RowHeaderTable.
How can I temporary show data for expanded cell in each row in RowHeaderTable, if the top line row with data has been scrolled up away?
wolfgang
Re: RowHeaderTable - show data for expanded cell in each row
Postby JIDE Support » Tue Mar 27, 2012 10:41 am
I'm afraid that there is no easy way to show the data for that scenario.
Postby wolfgang » Thu Mar 29, 2012 2:27 am
It might well be that I am on wrong track, but can RowHeaderTable with aggregation view of data easily during application running switch to 'normal' view of JTable, where all rows show own data?
wolfgang
Postby JIDE Support » Thu Mar 29, 2012 8:30 am
Please give JIDE AggregateTable a try if you want to show original rows.
B.T.W., it seems that your email address registered in this forum is not valid any more. Can you please update your email address so that we could contact you easier? We also would like to know how your evaluation process is going.
Postby wolfgang » Fri Mar 30, 2012 12:14 am
done
wolfgang
