JIDE and Mac compatibility
Postby MatthewCavillo » Tue Mar 06, 2012 3:27 am
Hi!
I have some questions about JIDE framework and Mac OS X 10.4.11 compatibility. Java version is 1.5.0_19.
Running the file jide_demo.jar the terminal log this error:
java[306] CFLog (0): CFMessagePort: bootstrap_register(): failed 1103 (0x44f), port = 0x10a03, name = 'java.ServiceProvider'
See /usr/include/servers/bootstrap_defs.h for the error codes.
2012-03-06 11:07:51.600 java[306] CFLog (99): CFMessagePortCreateLocal(): failed to name Mach port (java.ServiceProvider)
When I select an example from the JIDE Grids category, I obtain this exceptions:
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: com.jidesoft.plaf.aqua.AquaCellStyleTableHeaderUI.rolloverColumnUpdated(II)V
        at com.jidesoft.plaf.aqua.AquaCellStyleTableHeaderUI.setRolloverColumn(Unknown Source)
        at com.jidesoft.plaf.basic.BasicCellStyleTableHeaderUIDelegate.a(Unknown Source)
        at com.jidesoft.plaf.basic.BasicCellStyleTableHeaderUIDelegate.mouseEntered(Unknown Source)
        at com.jidesoft.plaf.basic.BasicSortableTableHeaderUIDelegate.mouseEntered(Unknown Source)
        at com.jidesoft.plaf.aqua.AquaCellStyleTableHeaderUI$MouseInputHandler.mouseEntered(Unknown Source)
        at java.awt.AWTEventMulticaster.mouseEntered(AWTEventMulticaster.java:242)
        at java.awt.Component.processMouseEvent(Component.java:5592)
        at javax.swing.JComponent.processMouseEvent(JComponent.java:3135)
        at java.awt.Component.processEvent(Component.java:5348)
        at java.awt.Container.processEvent(Container.java:2010)
        at java.awt.Component.dispatchEventImpl(Component.java:4050)
        at java.awt.Container.dispatchEventImpl(Container.java:2068)
        at java.awt.Component.dispatchEvent(Component.java:3885)
        at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4256)
        at java.awt.LightweightDispatcher.trackMouseEnterExit(Container.java:4061)
        at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3918)
        at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3866)
        at java.awt.Container.dispatchEventImpl(Container.java:2054)
        at java.awt.Window.dispatchEventImpl(Window.java:1791)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
        at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Have you any suggestion to avoid these exceptions?
Thank you in advance.
MatthewCavillo
Re: JIDE and Mac compatibility
Postby JIDE Support » Tue Mar 06, 2012 9:25 am
Unfortunately JIDE won't work with JDK5 on Mac. We officially only support JDK6 and JDK7. While we could keep minimum JDK5 compatible on Windows and Linux, it is very difficult to keep the compatibility with JDK5 on Mac.
Postby JIDE Support » Tue Mar 06, 2012 10:09 am
Please give the latest 3.3.6 a try which should fix the NoSuchMethodError. However I am not sure what CFMessagePort error is.
The main reason I said it is hard to be compatible with JDK5 on Mac is because Apple changed their package name from apple.laf (on JDK5) to com.apple.laf (on JDK6), for example AquaTableHeaderUI. Right now we are still extending the classes in apple.laf for backward compatible reason (they are deprecated at the moment) but sooner or later, when Apple removes the deprecated classes under apple.laf, we will have to use the classes in com.apple.laf, which will break your application when running on JDK5.
Postby rogerbj » Tue Jul 03, 2012 1:37 pm
From which JIDE version is Java 7 supported on OS X? I couldn't find it in the change log.
rogerbj
Postby JIDE Support » Tue Jul 03, 2012 7:18 pm
There were several JDK7 compatibility issues addressed back in 3.2.0. Please feel free to let us know if you observe any issue after 3.2.0.
