Get selected cells of pivot table
Postby wolfgang » Fri Feb 24, 2012 2:29 am
I use this code, to get selected cells in pivot table:
            int rowIndexStart = dataTable.getSelectedRow();
            int rowIndexEnd = dataTable.getSelectionModel().getMaxSelectionIndex();
            int colIndexStart = dataTable.getSelectedColumn();
            int colIndexEnd = dataTable.getColumnModel().getSelectionModel().getMaxSelectionIndex();
            for (int r = rowIndexStart; r <= rowIndexEnd; r++) {
                for (int c = colIndexStart; c <= colIndexEnd; c++) {
                    if (dataTable.isCellSelected(r, c)) {
                        System.out.println( r + " " + c);
On <MouseClick + Ctrl> every cells in every rows are detected. When I use <Key Arrow Left/Right + Shift> only cells of one row are detected. What is wrong with my code above or what alternative I have, please?
wolfgang
Postby wolfgang » Fri Feb 24, 2012 3:42 am
Additional: It seems, only cells of that row are detected with code above, which has the focused cell (dashed line border). Is there another way to get selected Cells of DataTable by <KeyEvent + Shift>?
wolfgang
Re: Get selected cells of pivot table
Postby JIDE Support » Fri Feb 24, 2012 8:39 am
By default, DataTable uses non-contiguous cell selection. Please use getTableSelectionModel() instead to retrieve the selection information.
Postby wolfgang » Thu Mar 01, 2012 12:40 am
thanks a lot. :D
wolfgang
