Searchable Bar Layout Problem
Postby robert » Wed Feb 22, 2012 3:34 pm
I am using a Searchable Bar in my application and have customized it because I don't want to show the highlight button:
searchBar.setVisibleButtons(searchBar.SHOW_CLOSE | searchBar.SHOW_NAVIGATION | searchBar.SHOW_MATCHCASE);
However, when I do this, the layout of the bar gets messed up. The "Find" label and each button is larger than it should be:
When I comment out the above code, the bar is displayed properly:
Is this a bug, or is there some way to correct this.
robert
Re: Searchable Bar Layout Problem
Postby JIDE Support » Wed Feb 22, 2012 4:03 pm
Please also add SearchableBar because that's the component which stretches to keep the right layout when there are more horizontal spaces.
searchableBar.setVisibleButtons(SearchableBar.SHOW_CLOSE | SearchableBar.SHOW_NAVIGATION | SearchableBar.SHOW_MATCHCASE| SearchableBar.SHOW_STATUS);
Postby robert » Wed Feb 22, 2012 5:37 pm
Thanks for the solution. It works well now.
robert
