JIDE plugin with netbeans
Postby tbijisha » Fri Feb 03, 2012 1:59 am
I am a beginner in java application. I am developing an application in which i want autocompletion of jTable and jTextField. I am using netbeans. Now a days i came to know that JIDE is providing that feature as intelliHint and autocompletion. But i dont know how can i get that into my netbeans application. For adding that API as library i couldnt download the jar files of JIDE. I am totally confused in this. So any one please help me to do this, i am completely new to JIDE.
tbijisha
Re: JIDE plugin with netbeans
Postby JIDE Support » Fri Feb 03, 2012 9:26 am
You could download the AutoCompletion and IntelliHint from JIDE open source project at http://java.net/projects/jide-oss/downloads.
Postby JIDE Support » Fri Feb 03, 2012 9:35 am
BTW, since you are new to JIDE, you probably don't know the webstart demo and evaluation package. The JCL library (the jar itself) is available on java.net but the demo for it is in the eval package which you can download from http://www.jidesoft.com/evaluation/. We can't put it on java.net as the demo framework itself depends on some other JIDE components. Once you get the eval package, unzip it and open the examples project in NetBeans, you can see a lot of demos. There are demos for AutoCompletion and IntelliHints respectively. You can look at the source code of the demo to figure out how to use these two features. Just so you know, you need to write code for it. It is just a couple of lines of simple code but you can't enable the features by drag-n-drop using NetBeans GUI builder.
Postby tbijisha » Sat Feb 04, 2012 1:13 am
Thanks for your reply..I'l try those things which you have mentioned and will let you know..
tbijisha
Postby tbijisha » Wed Feb 15, 2012 2:57 am
Hii..i downloaded the jar files from http://java.net/projects/jide-oss/downloads. But there i found so many versions of jide-oss. I tried 3.3.4 , 2.11.1 and 3.1.1. After opening it in netbeans i got only AutocompletionCombobox,i didnt get IntelliHints and autocompletion Text Field. Can you tell me the exact version of jide-oss which contains these two.
tbijisha
Postby JIDE Support » Wed Feb 15, 2012 9:21 am
IntelliHints and AutoCompletion are two classes, not java bean so they won't show up in the NB palette. What you should do is to drag a Swing JTextField to the GUI designer, then in your code, you get hold a reference to the JTextField and call new ListDataIntelliHints(textField, a completionList) or new AutoCompletion(textField, a completionList) to implement the IntelliHint or AutoCompletion feature respectively.
Postby tbijisha » Wed Feb 15, 2012 9:18 pm
ok..i'll try the way you said....thank you..
tbijisha
Postby tbijisha » Mon Mar 05, 2012 11:10 pm
Thank you all...now it's working..thanks a lot...:)
tbijisha
Users browsing this forum: Bing [Bot] and 91 guests
