by bstung » Wed Feb 01, 2012 12:46 pm
I have a JideSplitPane which splits vertically, a master grid at top and a detail grid in the bottom. If I do setProportionalLayout(true), the 2 grids are split with equal size. Is there a way i can set the location where master grid can show more rows than the detail grid?
bstung
by JIDE Support » Wed Feb 01, 2012 2:01 pm
You could invoke JideSplitPane#setDividerLocation() to change the size.
by bstung » Wed Feb 01, 2012 2:11 pm
Is this the one I should use setDividerLocation(int dividerIndex, int location)? what should I pass for divderIndex?
bstung
by JIDE Support » Wed Feb 01, 2012 2:24 pm
Yes, it is. If you have only two tables in your JideSplitPane, the divider index should be 0. You could also set the preferred size of the tables to control the layout.
