TreePath in CheckBoxTree
Postby nick.denton » Wed Jan 18, 2012 10:30 am
I have a problem to receive all the paths when all the nodes of a Parent are selected.
What I mean is : If the parent node has 3 kids and all the kids are selected, then by using something like that:
TreePath[] treePaths = myTree.getCheckBoxTreeSelectionModel().getSelectionPaths();
I am receiving only the path for the parent node.
But if one of the kids is not selected I am receiving the path of the two selected kids.
So my question is is there any way to receive the path for all the selected, nodes that are leafs?
nick.denton
Re: TreePath in CheckBoxTree
Postby JIDE Support » Wed Jan 18, 2012 10:56 am
That's the default behavior when isDigIn() returns false. When a parent node is selected, all its descendant nodes are selected.
Postby nick.denton » Thu Jan 19, 2012 5:54 am
Thanks for the answer.
But I know that when a parent node is selected all its descendant nodes are selected.
My question is how I can get the paths of all the selected nodes that are leafs (they don't have descendant nodes). But keeping the DigIn true.
nick.denton
Postby JIDE Support » Thu Jan 19, 2012 8:15 am
In dig in mode, you'll have to iterate the selected parent node to get all its descendant nodes. You could also try to invoke setDigIn(false) so that whatever node is selected, it is appeared in the CheckBoxTreeSelectionModel#getSelectionPaths().
Postby nick.denton » Thu Jan 19, 2012 12:35 pm
Sorry but I don't get it.
Lets say I have this tree:
                     A
                 B      C
              D  E   F  G
           H   I
And the nodes (leafs) that are selected are H, I, F E, and G
How I will get the path for all of them? So if i press a button will print:
ABE
ABDH
ABDI
ACF
ACG
I cant see any function that will return me the selected nodes so i can iterate.
Can you provide a working simple example?
Thanks in advance
nick.denton
Postby JIDE Support » Thu Jan 19, 2012 3:29 pm
In your case, you will get just A or root from the getSelectionPaths(). You will then have to find A's children, B & C. Since B & C are not leaf nodes, keep digging it deeper to D/E/F/G. Keep going until all leaf nodes are navigated. Evemtually you will get the list you want, i.e., ABDH, ABDI, ABE, ACF, ACG.
Postby nick.denton » Fri Jan 20, 2012 4:15 am
Thanks, I understood that.
But how you iterate in a checkboxtree? I cant find a method
nick.denton
Postby JIDE Support » Fri Jan 20, 2012 7:52 am
Actually those methods are provided by native Swing.
Please invoke TreePath#getLastPathComponent() to get the last path component of the selected path. The last component should be an instance of DefaultMutableTreeNode. Please then invoke DefaultMutableTreeNode#getChildAt()/getChildCount() to get its children nodes.
