Exception when changing L&F during runtime
Postby safesoft » Wed Jan 11, 2012 8:14 pm
When I change L&F of my application during runtime, I got the following exception;
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.jidesoft.plaf.basic.BasicJideTabbedPaneUI.rotateInsets(Unknown Source)
at com.jidesoft.plaf.basic.BasicJideTabbedPaneUI.getTabAreaInsets(Unknown Source)
at com.jidesoft.plaf.basic.BasicJideTabbedPaneUI$TabbedPaneLayout.calculateSize(Unknown Source)
at com.jidesoft.plaf.basic.BasicJideTabbedPaneUI$TabbedPaneLayout.minimumLayoutSize(Unknown Source)
at java.awt.Container.minimumSize(Container.java:1651)
at java.awt.Container.getMinimumSize(Container.java:1636)
at javax.swing.JComponent.getMinimumSize(JComponent.java:1716)
at javax.swing.plaf.basic.BasicSplitPaneUI$BasicHorizontalLayoutManager.getMinimumSizeOfComponent(BasicSplitPaneUI.java:1621)
at javax.swing.plaf.basic.BasicSplitPaneUI$BasicHorizontalLayoutManager.distributeSpace(BasicSplitPaneUI.java:1943)
at javax.swing.plaf.basic.BasicSplitPaneUI$BasicHorizontalLayoutManager.layoutContainer(BasicSplitPaneUI.java:1328)
at java.awt.Container.layout(Container.java:1421)
at java.awt.Container.doLayout(Container.java:1410)
at java.awt.Container.validateTree(Container.java:1507)
at java.awt.Container.validateTree(Container.java:1513)
at java.awt.Container.validate(Container.java:1480)
at javax.swing.RepaintManager.validateInvalidComponents(RepaintManager.java:669)
at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(SystemEventQueueUtilities.java:124)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
It messes up the whole GUI and freezes the application.
This is what I call to update GUI
javax.swing.UIManager.setLookAndFeel(com.sun.java.swing.plaf.windows.WindowsLookAndFeel);
SwingUtilities.updateComponentTreeUI(this);
we are using version : 2.2.0
safesoft
Re: Exception when changing L&F during runtime
Postby JIDE Support » Wed Jan 11, 2012 8:38 pm
Did you invoke those code in EventDispatcherThread?
Postby safesoft » Thu Jan 12, 2012 12:03 pm
yes.
safesoft
Postby JIDE Support » Thu Jan 12, 2012 12:46 pm
Can you please give the latest JIDE release a try then? 2.2.0 is a quite old version, which was generated 4 years ago. Please also check if you have any thread other than EventDispatcherThread that is trying to update UI.
Postby safesoft » Thu Jan 12, 2012 1:41 pm
Thank you for the information. I update my jide version to 2.9.7. I can change L&F during run-time and there is no errors. However, If i enable SyntheticaLookAndFeel, and lunch the application, it will throw the following exception continuously;
Exception in thread "AWT-EventQueue-0" java.lang.RuntimeException: java.lang.ClassNotFoundException: de.javasoft.plaf.synthetica.painter.StatusBarPainter
at de.javasoft.plaf.synthetica.painter.SyntheticaComponentPainter.getInstance(SyntheticaComponentPainter.java:83)
at de.javasoft.plaf.synthetica.painter.SyntheticaAddonsPainter.getInstance(SyntheticaAddonsPainter.java:40)
at com.jidesoft.plaf.synthetica.SyntheticaJidePainter.paintStatusBarBackground(Unknown Source)
at com.jidesoft.status.StatusBar.paintComponent(Unknown Source)
at javax.swing.JComponent.paint(JComponent.java:1029)
at javax.swing.JComponent.paintChildren(JComponent.java:862)
at javax.swing.JComponent.paint(JComponent.java:1038)
at javax.swing.JLayeredPane.paint(JLayeredPane.java:567)
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5131)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1479)
at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1410)
at javax.swing.RepaintManager.paint(RepaintManager.java:1224)
at javax.swing.JComponent.paint(JComponent.java:1015)
at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:21)
at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:60)
at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:97)
at java.awt.Container.paint(Container.java:1780)
at java.awt.Window.paint(Window.java:3375)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:796)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:713)
at javax.swing.RepaintManager.seqPaintDirtyRegions(RepaintManager.java:693)
at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(SystemEventQueueUtilities.java:125)
Caused by: java.lang.ClassNotFoundException: de.javasoft.plaf.synthetica.painter.StatusBarPainter
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:169)
at de.javasoft.plaf.synthetica.painter.SyntheticaComponentPainter.getInstance(SyntheticaComponentPainter.java:72)
jide Version : 2.9.7
Synthetica Version : 2.14.1_eval
This is how I enabled synthetica;
SyntheticaSkyMetallicLookAndFeel laf = new SyntheticaSkyMetallicLookAndFeel();
SyntheticaLookAndFeel.setWindowsDecorated(false);
UIManager.setLookAndFeel(laf);
safesoft
Postby JIDE Support » Thu Jan 12, 2012 4:04 pm
I'm afraid that you might have to turn to Synthetica to ask for their help since it's one of Synthetica class that is missing.
Postby safesoft » Thu Jan 12, 2012 5:42 pm
Thank you for your help. appreciated.
safesoft
