Deselection problem in CheckBox Tree
Postby rathinamsm » Thu Jan 05, 2012 6:49 am
Hi Team,
I'm trying to use "Check Box Tree" using the Jide evaluation Version 3.3.2.
In the sample i'm have 2 CheckBoxTree with 3 Levels in Left and Right tree.
For Example:
Left Check Box Tree:
- Left Root
----- Level 1: Parent 1
----- ----- Level 2: Parent 1.1
----- ----- ----- Level 3 : Child 1
Level 3 : Child 2
Level 3 : Child 3
Level 3 : Child 4
-----Level 2: Parent 1.2
----- ----- (checked) Level 3 : Child 1
(checked) Level 3 : Child 2
(checked) Level 3 : Child 3
(checked) Level 3 : Child 4
When I Select the child in Left tree, i updated the RIGHT TREE. As a result the right tree is generated
Right Check Box Tree:
(All the checkbox are selected)
- Right Root
----- ----- Level 2: Parent 1.2
Level 3 : Child 2
Level 3 : Child 3
Level 3 : Child 4
Pre-Step: I selected all the childern in right tree.
My Need is:
Step 1: If I deselect the checkbox in "Child 4" in "Right Check Box Tree: Parent 1.2"
Expected Result:
1. I Need to remove the deselected Item. [ "Child 4" from Level 2: Parent 1.2. from the Right Tree ]
2. And to "Deselect the CheckBox" the same level child in Left Tree. [ remove ]
But the "Right Tree Checkbox: TreeSelectionListener" is triggered multiple times for
1. Removing of - Right RootParent and Adding of Child 1, 2, 3..
How to perform this operation.? to Achieve the Expected Result.
Please suggest is there any method to use in Jide. or Is there any alternate to handle this problem
Regards
Rathinam.M
rathinamsm
Re: Deselection problem in CheckBox Tree
Postby JIDE Support » Thu Jan 05, 2012 9:54 am
Please invoke CheckBoxTreeSelectionModel#setSingleEventMode(true) to have one event only.
Postby rathinamsm » Thu Jan 12, 2012 10:33 pm
With the continuation of the previous question, in CheckBox tree if the "parent node" checkbox is in "Mixed" state and if i try to use "removeSelectionPath" for the Parent Node is not reflecting".
Could you please suggest where could be the problem.?
rathinamsm
Postby JIDE Support » Fri Jan 13, 2012 8:15 am
When it's in mixed state, that means the node is not selected. That's why removeSelectionPaths() won't take effect. Please invoke addSelectionPaths() first then remove it.
Postby rathinamsm » Fri Jan 13, 2012 8:43 am
Thanks for the quick reply. I implemented the Step 1. AddSelection path and 2. RemoveSelectionPath.
Its working fine. :)
rathinamsm
