Help Edit DateComboBox
Postby eramirezj » Mon Jan 02, 2012 7:01 am
Hello, I am using a DateComboBox and I want to rename buttons, specifically where it says "TODAY" and "NONE" any suggestions to make this possible, thank you. :)
eramirezj
Re: Help Edit DateComboBox
Postby JIDE Support » Mon Jan 02, 2012 8:31 am
Please override DateComboBox#createDateChooserPanel() then override DateChooserPanel#getResourceString(). You could return a different string for keys like "Date.ok" and "Date.today".
Postby eramirezj » Mon Jan 02, 2012 11:18 am
sorry, my version of the jide is 2.9.5, where not exist the method CreateDateChooserPanel(),any other suggestions, i can not change version, thanks.
eramirezj
Postby JIDE Support » Mon Jan 02, 2012 11:30 am
Please try to use the following code to create a customized DateChooserPanel.
        DateComboBox dateComboBox = new DateComboBox() {
            public PopupPanel createPopupComponent() {
                final DateChooserPanel dateChooserPanel = new DateChooserPanel(getDateModel(), isShowTodayButton(), isShowNoneButton(), isShowWeekNumbers(), getLocale());
                dateChooserPanel.setTimeDisplayed(isTimeDisplayed());
                dateChooserPanel.setShowOKButton(isShowOKButton());
                dateChooserPanel.getSelectionModel().addDateSelectionListener(new DateSelectionListener() {
                    public void valueChanged(DateSelectionEvent e) {
                        Date date = dateChooserPanel.getSelectionModel().getSelectedDate();
                        Object dateInEditor = getEditor().getItem();
                        if (!((dateInEditor instanceof Date && dateInEditor.equals(date)) || (dateInEditor instanceof Calendar && ((Calendar) dateInEditor).getTime().equals(date)))) {
                            getEditor().setItem(date);
                            setSelectedItem(date, false);
                            getEditor().selectAll();
                return dateChooserPanel;
Postby eramirezj » Mon Jan 02, 2012 12:11 pm
when attempting to assign a button text to "NONE" and "TODAY" she says protected objects that are, thanks. :(
eramirezj
Postby JIDE Support » Mon Jan 02, 2012 12:25 pm
Sorry that I can't quite get where your problem is now. The following code works fine for me in 2.9.6 in JIDE ComboBoxDemo.
                final DateChooserPanel dateChooserPanel = new DateChooserPanel(getDateModel(), isShowTodayButton(), isShowNoneButton(), isShowWeekNumbers(), getLocale()) {
                    protected String getResourceString(String key, Locale locale) {
                        if ("Date.ok".equals(key)) {
                            return "Test OK";
                        else if ("Date.today".equals(key)) {
                            return "Test Today";
                        return super.getResourceString(key, locale);
Postby eramirezj » Mon Jan 02, 2012 1:07 pm
thank you very much, topic resolved
:D
eramirezj
Postby Kalyani » Tue Jan 03, 2012 12:55 am
Could you please guide me with the DateExComboBox.
I do not want the previous year button to be displayed.
I could do it in a simple DateChoosePanel but not in a DateExComboBox,even though it opens up a DateChooserPanel.
Could you please provide me with the sample Code
Kalyani
Postby JIDE Support » Tue Jan 03, 2012 10:04 am
Please give the following code a try.
    public class CustomizeDateExComboBox extends DateExComboBox {
        public CustomizeDateExComboBox() {
            super();
        public CustomizeDateExComboBox(DateModel model) {
            super(model);
                // override here to hide the button as you did in plain DateChooserPanel
                    Object old = getSelectedItem();
                    Date date = dateChooserPanel.getSelectedDate();
                    CustomizeDateExComboBox.this.fireItemStateChanged(new ItemEvent(CustomizeDateExComboBox.this, ItemEvent.ITEM_STATE_CHANGED, old, ItemEvent.DESELECTED));
                    CustomizeDateExComboBox.this.fireItemStateChanged(new ItemEvent(CustomizeDateExComboBox.this, ItemEvent.ITEM_STATE_CHANGED, date, ItemEvent.SELECTED));
Users browsing this forum: Bing [Bot] and 90 guests
