JideTabbedPane close butons
Postby pablovilas » Mon Dec 26, 2011 10:48 am
It seems that close button on tab doesn´t work here is my code:
JideTabbedPane pane = new JideTabbedPane();
pane .setUseDefaultShowCloseButtonOnTab(true);
also I have problems with:
contenedorPrincipal.setTabClosableAt(0, true);
Thank you.
pablovilas
Re: JideTabbedPane close butons
Postby JIDE Support » Mon Dec 26, 2011 1:12 pm
Will fix the close button issue when isUseDefaultShowCloseButtonOnTab() returns true in next regular release.
However, for the setTabCloseable(), I could not observe any issue. Can you please describe the issue you observed a little bit more?
Postby pablovilas » Wed Dec 28, 2011 5:54 am
using:
contenedorPrincipal.setShowCloseButton(true);
contenedorPrincipal.setTabClosableAt(0, false);
works justs ok, so it´s a consequence of
returns false.
Thank you.
pablovilas
Postby JIDE Support » Wed Dec 28, 2011 7:08 am
Thanks for clarification. Will fix the issue in next regular release.
Postby JIDE Support » Tue Jan 03, 2012 12:27 pm
Happy new year. Just checked this issue again and it turns out that setUseDefaultShowCloseButtonOnTab(true) has to work together with setShowCloseButton(true). If both method are invoked and the key "JideTabbedPane.showCloseButtonOnTab" in UIDefaults is also assigned to true, the close button should be able to be displayed in the tab. Click on the close button in the tab to close a tab also works for me. Please correct me if I happen to miss anything.
Postby pablovilas » Wed Jan 04, 2012 5:58 am
Happy new year for you too. Just to let you know I use this code and work correctly
//Turn on the key
UIManager.getDefaults().put("JideTabbedPane.showCloseButtonOnTab",true);
//Instantiate the tabbed pane
JideTabbedPane tabs = new JideTabbedPane();
tabs.setShowCloseButton(true);
tabs.setUseDefaultShowCloseButtonOnTab(true);
pablovilas
Users browsing this forum: Bing [Bot] and 91 guests
