by Kalyani » Mon Dec 19, 2011 1:35 am
Hi I am making a LabeledTextField inside a JPanel.
I need to have the label have a different background color and the textField a different Background color. But it does not work.
labeledTextField1.setOpaque(true);
labeledTextField1.setLabelText("PortfolioName");
labeledTextField1.getLabel().setBackground(Color.RED);
The background color does not set to Red for the label.
However if i try changing the foreground color,that works.
labeledTextField1.getLabel().setForeground(Color.RED);
Could you please help me out. ?
Kalyani
by JIDE Support » Mon Dec 19, 2011 8:06 am
Please give the following code a try.
- Code: Select all
_filterField.getLabel().setOpaque(true);
_filterField.getLabel().setBackground(Color.red);
