Change Jide Look and Feel Colors
Postby pablovilas » Tue Dec 06, 2011 11:06 am
I just want to change some colors in "Office2007" look, it´s enough just override the painter class (Office2007Painter.java)?. And how I can force to my code that just use my new custom painter with Office2007 extension style. Thank you very much.
pablovilas
Re: Change Jide Look and Feel Colors
Postby JIDE Support » Tue Dec 06, 2011 11:15 am
Can you please list what colors you want to change?
Postby pablovilas » Tue Dec 06, 2011 11:18 am
All skyblues colors, example: CommandBar background color, JideTabbedPane tabs colors, etc. As I can see some of then are customizables by
UIDefaultsLookup.getColor("JideTabbedPane.background");
but also wanna change others. Thank you
pablovilas
Postby JIDE Support » Tue Dec 06, 2011 11:41 am
For CommandBar, please override Office2007Painter#paintCommandBarBackground(). For JideTabbedPane tab color, please invoke the following code.
                UIManager.getDefaults().put("JideTabbedPane.background", Color.red);
Postby pablovilas » Tue Dec 06, 2011 11:52 am
Thank you very much for your answer, but how can I force to use my new override painter class?. Thank you very much.
pablovilas
Postby JIDE Support » Tue Dec 06, 2011 11:56 am
Please put your customized painter instance into the UIDefaults with the key "Theme.painter".
Postby pablovilas » Tue Dec 06, 2011 12:41 pm
Just work fine!. Thanks you very much :).
pablovilas
