by Reyada Wolak » Thu Nov 10, 2011 12:51 am
I'm trying to deselect all the nodes from checkboxtree. this line is not working for me:
searchTree.getCheckBoxTreeSelectionModel().removeSelectionPaths(new TreePath[]{searchTree.getPathForRow(1)});
or
searchTree.getCheckBoxTreeSelectionModel().removeSelectionPaths(new TreePath[]{new TreePath(searchTree.getModel().getRoot())});
am i doing something wrong here
Reyada Wolak
by JIDE Support » Thu Nov 10, 2011 2:20 pm
May I ask which JIDE release you are using. The first statement you use does work for me. Attached is the test case FYI. Your second one will not take effect because the TreePath does not exist inside the CheckBoxTree. Please also look at the test case for how you could select the root path.
- Attachments
CheckBoxTreeDemo.java
- (11.93 KiB) Downloaded 2605 times
by Reyada Wolak » Sun Nov 13, 2011 3:29 am
my mistake i was doing something wrong in my code.
thanks for the response
Reyada Wolak
