JidePopup with Synthetica
Postby TuTranQuoc » Fri Oct 21, 2011 5:16 am
I want to customize JidePopup look and feel with Synthetica but I can not do it. By default, It using Synthetica PopupMenu background but when create the new one with specify name it still use the PopupMenu background again.
I look in your code and see you set the name of _window to "JidePopup", I am using it to custom Synthetica PopupMenu but it's not work. Do you have any suggestion? or I did something wrong?
Best Regards,
TuTranQuoc
Re: JidePopup with Synthetica
Postby JIDE Support » Fri Oct 21, 2011 7:43 am
Sorry but I didn't quite understand your question. I know for sure the name of "JidePopup" shouldn't matter as Synthetica (which is from another company) won't check for the name we set and do something else. If you could create an example and show us what you mean exactly, it would be very helpful.
Users browsing this forum: No registered users and 90 guests
