TaskTreeTableModel addRows does not always work in an unsort
Postby ElenaHomeEmails » Fri Oct 14, 2011 10:25 am
Iam evaluating jide's treetables and TaskTreeTableModel.addRows does not always work in an unsorted table. To reproduce just run webStart for http://www.jidesoft.com/products/download.htm
run AutoFilterTreeTableDemo and click on button "Add 3 rows under selected row".
Sometines rows are added indeed into selected row but somethis they are added into incorrect row.
Did anyone else see it? Is it a known issue? What's the fix?
Thanks !
ElenaHomeEmails
Re: TaskTreeTableModel addRows does not always work in an un
Postby JIDE Support » Fri Oct 14, 2011 11:04 am
Thanks for bug report. Will fix it in next regular release.
Postby JIDE Support » Fri Oct 21, 2011 4:00 pm
Just so you know, this is fixed in 3.2.4 just released.
Postby ElenaHomeEmails » Tue Nov 22, 2011 7:31 am
Thank you! I will check it out !
ElenaHomeEmails
