Change Row Background Color After setCellStyleProvider
Postby ginofranco » Thu Oct 06, 2011 5:36 am
I have a situation where the table/grid was configured to have row stripes but I also have a use case where I should change the background color of the row afterwards with some conditions.
I tried changing the background color using setBackground from the swing library but it doesn't change anything. I tried doing setForeground and it was working fine.
Is changing the background color after setting the row stripes possible?
ginofranco
Re: Change Row Background Color After setCellStyleProvider
Postby JIDE Support » Thu Oct 06, 2011 6:28 am
Please let your original table model implement StyleModel then return a CellStyle with different background. Please also invoke CellStyle#setPriority() to set a higher priority than 0. As long as you turned style on via row stripe or StyleModel, cell renderers will have background which obsolete the table.getBackground().
Postby ginofranco » Thu Oct 06, 2011 6:40 am
Thank you for the response.
Do you have any example from that?
ginofranco
Postby JIDE Support » Thu Oct 06, 2011 6:44 am
Please give JIDE AbstractStyleTableDemo a try for the detailed implementations.
