BasicJideTabbedPaneUI tab editing bug
Postby poss » Wed Oct 05, 2011 10:11 am
Hi i am using jide-oss-2.5.5 with Standart JDK 1.6.12.
I have a class that is inherited from BasicJideTabbedPaneUI and i have problems with tab editing.
The problems is: when the title of the tab is bigger than the max tab width, the title is displayed as "veryveryveryverylongtitle...".
When i try to edit this tab, the editor is displayed correctly, in the bounds of max tab size, but the whole tab is painted as if its width is the width of full title.
what i get is tab : |"editor with title"|X_____________________|
Where X is a close button
and ___ is the tabs empty space.
I looked at the source code, Overrided the editTabAt method and found out, that the width of the tab remains normal(maximum tab width width) until the the line
_isEditing = true;
is executed.
Would very appreciate help
poss
Re: BasicJideTabbedPaneUI tab editing bug
Postby JIDE Support » Wed Oct 05, 2011 10:51 am
Can you please give the latest release a try? Just tried JIDE JideTabbedPaneDemo in 3.2.3 and the tab editing works fine for me.
Postby poss » Thu Oct 06, 2011 9:26 am
The problem was in method:
protected int calculateTabWidth(int i, int j, FontMetrics fontmetrics)
In BasicJideTabbedPaneUI.
in this method, the tab width was calculated incorrectly( adding the width of whole tab title);
poss
Postby JIDE Support » Thu Oct 06, 2011 4:18 pm
Thanks for your help debugging this issue. Appreciate if you could send us a screencast to demonstrate the issue if you still see it in the latest release. The link here http://screencast.com/t/PD2Q5Pa4kUXP is the screencast I tested FYI
