JideTabbedPane scroll buttons
Postby poss » Mon Oct 03, 2011 9:23 am
Hi i am using jide-oss-2.5.5 with Standart JDK 1.6.12.
I have a class inherited from JideTabbedPane and the scrolling buttons(forward/backward) are not working.
Could you please tell me, how to access these buttons, so that i could change listeners/implement my own.
The list button is working correctly
poss
Re: JideTabbedPane scroll buttons
Postby JIDE Support » Mon Oct 03, 2011 9:44 am
Please give the following code a try. It will also help if you let us know how you override the class.
                new JideTabbedPane();
                ActionMap map = (ActionMap) UIDefaultsLookup.get("JideTabbedPane.actionMap");
                map.put("scrollTabsForwardAction", new AbstractAction() {
                        System.out.println("scroll forward");
                map.put("scrollTabsBackwardAction", new AbstractAction() {
                        System.out.println("scroll backward");
Postby poss » Mon Oct 03, 2011 10:24 am
I tried this code, but it doesn't work, the commands in actionPerformed method are not executed.
poss
Postby JIDE Support » Mon Oct 03, 2011 11:19 am
Sorry that I didn't mention the tricky part. The JideTabbedPane instantiation in my posted code is just to make sure the entry "JideTabbedPane.actionMap" is registered in UIDefaults. You have to create your JideTabbedPane instances after these code.
Postby poss » Mon Oct 03, 2011 11:09 pm
Ok i inserted this code just before instantiating my inherited class, and still the commands in scroll buttons are not executed.
poss
Postby JIDE Support » Mon Oct 03, 2011 11:18 pm
I wonder if you misunderstood the meaning of scroll buttons. It is not to change the selected tab but to scroll the tab area left and right when there are too many tabs.
Postby poss » Mon Oct 03, 2011 11:41 pm
I am very sorry. You are absolutely right, i thought these buttons were to change selected tab.
Thanks for great support!
poss
