TristateCheckBox is not painting mixed icon on clicking
Postby Wladimir82 » Wed Sep 28, 2011 4:07 am
If the initial state of the TristateCheckBox ist not mixed. The mixed state icon is not painted when cycling through by clicking on it.
It works only if the state is set by code.
As workaround I had to listen for the state by addActionListener and set the current state back into the TristateCheckBox by code.
        tristate = new TristateCheckBox("Tristate");
        tristate.addActionListener(new ActionListener()
            public void actionPerformed(ActionEvent e)
                tristate.setState(tristate.getState());
        tristate.setState(TristateCheckBox.STATE_UNSELECTED);
I suppose this behaviour is a bug.
Tested in 3.1.1 and 3.2.2 with Java 1.6_27 on Windows7 64bit
TristateCheckBoxMain.java
Example with workaround
(1.58 KiB) Downloaded 2260 times
Wladimir82
Re: TristateCheckBox is not painting mixed icon on clicking
Postby JIDE Support » Wed Sep 28, 2011 8:35 am
Thanks for the test case and detailed bug report. Will fix it in next regular release.
Postby JIDE Support » Thu Sep 29, 2011 9:46 pm
Just so you know, this is fixed in 3.2.3 just released.
Postby Wladimir82 » Fri Sep 30, 2011 7:57 am
nice, it works.
Thank you
Wladimir82
