TableExComboBox
TableExComboBox
Postby pablovilas » Thu Sep 22, 2011 11:33 am
Is there any way to show a real (with close, maximize, buttons) popup in a TableExComboBox?. Or just I have write my own ExComboBox component?.
Thanks. :)
pablovilas
Re: TableExComboBox
Postby JIDE Support » Thu Sep 22, 2011 12:19 pm
You might have to override TableExComboBox#createPopupComponent() to achieve your goal. However, where do you want to maximize if the customer click the maximize button? In next regular release, the popup component would be able to be resized by default.
Re: TableExComboBox
Postby pablovilas » Thu Sep 22, 2011 12:55 pm
I just want to see a window like in MultilineStringExComboBox but with the jTable inside and maximize box. Because my "Selection Panel" it´s more complex and I want to use it generically.
BTW: If you set the JTable as a SortableTable with AutoFilterTableHeader, that just don´t work because user cannot type any filter word, the ExComboBox doesn´t loose focus and just don´t let you write in filters input text.
pablovilas
Re: TableExComboBox
Postby JIDE Support » Thu Sep 22, 2011 1:46 pm
Please try to invoke tableComboBox.setPopupType(ExComboBox.DIALOG) to have the effect you want.
Can you please describe the focus issue a little bit more? As I can see, after drop down the popup panel, you could still enter characters to search it. If you do have focus issue, please give the following code a try.
        TableExComboBox tableComboBox = new TableExComboBox(DemoData.createQuoteTableModel()) {
            protected JTable createTable(TableModel model) {
                final SortableTable sortableTable = new SortableTable(model);
                AutoFilterTableHeader header = new AutoFilterTableHeader(sortableTable);
                header.setAutoFilterEnabled(true);
                header.setUseNativeHeaderRenderer(true);
                sortableTable.setTableHeader(header);
                return sortableTable;
            public PopupPanel createPopupComponent() {
                PopupPanel popupComponent = super.createPopupComponent();
                popupComponent.setRequestFocusEnabled(true);
                popupComponent.setFocusable(true);
                return popupComponent;
Re: TableExComboBox
Postby pablovilas » Fri Sep 23, 2011 6:53 am
Well, using:
tableComboBox.setPopupType(ExComboBox.DIALOG);
there is no focus problem, but if you try to run this code no focus to input filter text it´s available (I cannot search anything).
MyTableExCombobox tableComboBox = new MyTableExCombobox(new QuoteTableModel()) {
               AutoFilterTableHeader cabezal = new AutoFilterTableHeader(sortableTable) {
                private static final long serialVersionUID = -8981103560551395381L;
                   protected IFilterableTableModel createFilterableTableModel(TableModel model) {
                       return new FilterableTableModel(model) {
                           private static final long serialVersionUID = 7072186511643823323L;
                           public boolean isColumnAutoFilterable(int column) {
                              return true;
                           public boolean isValuePredetermined(int column) {
                              return true;
                   protected void customizeAutoFilterBox(AutoFilterBox autoFilterBox) {
                       super.customizeAutoFilterBox(autoFilterBox);
                       autoFilterBox.setSearchingDelay(-1);
               cabezal.setAutoFilterEnabled(true);
               cabezal.setAcceptTextInput(true);
               sortableTable.setTableHeader(cabezal);
               TableHeaderPopupMenuInstaller installer = new TableHeaderPopupMenuInstaller(sortableTable);
               installer.addTableHeaderPopupMenuCustomizer(new AutoResizePopupMenuCustomizer());
               installer.addTableHeaderPopupMenuCustomizer(new TableColumnChooserPopupMenuCustomizer());
        tableComboBox.setValueColumnIndex(1); // display the second column value in the combobox.
        tableComboBox.setSelectedItem("ALCOA INC");
        tableComboBox.setMaximumRowCount(12);
        tableComboBox.setEditable(true);
MyTableExComboBox Class:
public class MyTableExComboBox extends TableExComboBox{
   public MyTableExComboBox (TableModel model) {
      super(model);
      PopupPanel panel = super.createPopupComponent();
      panel.setRequestFocusEnabled(true);
      panel.setFocusable(true);
      return panel;
Anything else you need please let me know. Greetings.
pablovilas
Re: TableExComboBox
Postby pablovilas » Fri Sep 23, 2011 7:16 am
Also I think by default if using
The selection should not follow mouse movements because we have an accept, cancel buttons. Of corse it´s not a real selection (you need double click to select).But it's very confusing
that selection highlight follows mouse.
When you use the default popup this it´s cool because you just want double click one and close the popup at same time.
pablovilas
Re: TableExComboBox
Postby JIDE Support » Fri Sep 23, 2011 9:12 am
Will add an option to turn off the feature that mouse over could make selection. I'm afraid there is no easy solution to let the AutoFilterTableHeader to obtain focus if the popup type is POPUP.
Re: TableExComboBox
Postby pablovilas » Fri Sep 23, 2011 10:05 am
Okay, thank you very much.
pablovilas
Re: TableExComboBox
Postby JIDE Support » Thu Sep 29, 2011 10:06 pm
Just so you know, this is fixed in 3.2.3 just released.
Re: TableExComboBox
Postby pablovilas » Fri Sep 30, 2011 6:24 am
Excellent!! Thanks.
pablovilas
