TreeTable with comboBox CellEditor
Postby robertho21 » Thu Sep 15, 2011 8:51 am
I'm trying to set a ComboBox CellEditor in a TreeTable without success, Previously I had the same implementation with a simple JTable and custom cell editors work well, do you have an Example how could I use a comboBox cell editor instead the simple text cell editor. my code is online:
// setting the combobox to the specific column of the table:
      alertPropertiesTable
            .getColumnModel()
            .getColumn(2)
            .setCellEditor(
                  new AlertComboBoxCellEditor(new JComboBox(
                        numberCriteria)));
// custom cell editor
   private class AlertComboBoxCellEditor extends DefaultCellEditor implements
         TableCellEditor {
      private AlertComboBoxCellEditor(final JComboBox comboBox) {
         super(comboBox);
      public Component getTableCellEditorComponent(final JTable table,
            final Object value, final boolean isSelected, final int row,
            final int column) {
         final JComboBox comboBox = (JComboBox) super
               .getTableCellEditorComponent(table, value, isSelected, row,
                     column);
         if (!entryPanel.hasChanges()) {
            entryPanel.setChanged(true);
         comboBox.setBorder(BorderFactory.createLineBorder(Color.black));
         comboBox.setSelectedItem(value);
         return comboBox;
robertho21
Re: TreeTable with comboBox CellEditor
Postby JIDE Support » Thu Sep 15, 2011 11:16 am
Please give JIDE PropertyPaneDemo a try. PropertyTable is a subclass of TreeTable. In that demo, we registered a lot of combo box cell editor. I would recommend you use CellEditorManager to register cell editors for your table, which will help you persist cell editors even if table structure changed event is received. Regarding the combo box cell editor itself, there is a trick that you need put a client property, "JComboBox.isTableCellEditor", to JComboBox to let it know it's being used as a cell editor.
