NPE on JideTabbedPane
Postby andrednasoftware » Thu Sep 08, 2011 6:09 am
When using JideTabbedPane on Netbeans and try to set a name on tab a NPE occurs:
java.lang.NullPointerException
at com.jidesoft.plaf.basic.BasicJideTabbedPaneUI.paint(Unknown Source)
at javax.swing.plaf.ComponentUI.update(ComponentUI.java:161)
at javax.swing.JComponent.paintComponent(JComponent.java:778)
at javax.swing.JComponent.paint(JComponent.java:1054)
at javax.swing.JComponent.paintChildren(JComponent.java:887)
at javax.swing.JComponent.paint(JComponent.java:1063)
at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:39)
at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:78)
at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:115)
at java.awt.Container.paint(Container.java:1967)
at org.netbeans.modules.form.fakepeer.FakePeerContainer.paint(FakePeerContainer.java:89)
at javax.swing.JComponent.paintChildren(JComponent.java:901)
[catch] at org.netbeans.modules.form.ComponentLayer$DesignerPanel.paint(ComponentLayer.java:190)
at org.netbeans.modules.form.FormDesigner$1.paintChildren(FormDesigner.java:240)
at javax.swing.JLayeredPane.paint(JLayeredPane.java:585)
at javax.swing.JViewport.paint(JViewport.java:725)
at org.netbeans.swing.tabcontrol.TabbedContainer.paint(TabbedContainer.java:959)
at org.netbeans.core.windows.view.ui.MultiSplitPane.paint(MultiSplitPane.java:330)
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5221)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1482)
at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1413)
at javax.swing.BufferStrategyPaintManager.paint(BufferStrategyPaintManager.java:311)
at javax.swing.RepaintManager.paint(RepaintManager.java:1206)
at javax.swing.JComponent._paintImmediately(JComponent.java:5169)
at javax.swing.JComponent.paintImmediately(JComponent.java:4980)
at javax.swing.JComponent.paintImmediately(JComponent.java:4961)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:770)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:728)
at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:677)
at javax.swing.RepaintManager.access$700(RepaintManager.java:59)
at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1621)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:251)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:705)
at java.awt.EventQueue.access$000(EventQueue.java:101)
at java.awt.EventQueue$3.run(EventQueue.java:666)
at java.awt.EventQueue$3.run(EventQueue.java:664)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:675)
at org.netbeans.core.TimableEventQueue.dispatchEvent(TimableEventQueue.java:148)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:211)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:128)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:117)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:113)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
andrednasoftware
Re: NPE on JideTabbedPane
Postby JIDE Support » Thu Sep 08, 2011 6:35 am
Looks like the _tabbedPane field in the BasicJideTabbedPaneUI is null at that moment, which should not happen. Can you please let us know the steps that you reproduce the issue in Netbeans? We will try to see if we could reproduce it on our end.
Postby andrednasoftware » Thu Sep 08, 2011 6:52 am
The steps are:
1- Drag a JideTabbedPane from Pallete into a Jpanel
2- Drag a JPanel into JideTabbedPane to construct a Tab
3- DoubleClick on Tab title to edit
4- Replace the default title "tab1" with a new title and press Enter
Then a stack trace is diaplayed above the form.
andrednasoftware
Postby JIDE Support » Thu Sep 08, 2011 9:39 am
Just tried the latest JIDE release with NetBeans 6.9.1 but could not reproduce the issue. Can you please let me know your JIDE and NetBeans version?
Postby andrednasoftware » Thu Sep 08, 2011 9:48 am
NetBeans IDE 7.0.1 (Build 201107282000)
Java: 1.7.0; Java HotSpot(TM) Client VM 21.0-b17
JIDE 3.2.1
andrednasoftware
Postby andrednasoftware » Mon Oct 03, 2011 6:08 am
Thank you for your attention.
Were you able to reproduce the problem? Found some solution ?
andrednasoftware
Postby JIDE Support » Mon Oct 03, 2011 4:06 pm
Sorry that somehow we missed your post. Tried the JIDE 3.2.3, JDK 1.7.0 and Netbeans 7.0.1 but could not reproduce the issue. The screencast is uploaded at http://screencast.com/t/elowIQFge9Ab FYI.
Postby andrednasoftware » Tue Oct 04, 2011 5:17 am
You forgot the step 3 and 4.
andrednasoftware
Postby JIDE Support » Tue Oct 04, 2011 9:50 am
Thanks. I do see the JideTabbedPane disappears on changing the text although it could be displayed later by choosing it. However, I cannot see any stack information regarding an exception. Not sure if I missed anything since Netbeans is not the IDE I frequently use. The screencast is posted here FYI. http://screencast.com/t/4rBCi1Iz
Postby andrednasoftware » Tue Oct 04, 2011 10:49 am
I don't know exactly why the exception was not displayed for you.
In my tests everything happens differently.
A screencast might help you out on something, http://screencast.com/t/oHWFzVfvg
andrednasoftware
Postby JIDE Support » Tue Oct 04, 2011 11:25 am
May I ask which OS you are using? Looks like it's not Windows.
Postby andrednasoftware » Tue Oct 04, 2011 1:20 pm
It's Windows XP (SP3)
andrednasoftware
Postby JIDE Support » Tue Oct 04, 2011 3:24 pm
Unfortunately, I cannot reproduce the issue in Windows XP machine either. Since the NPE indicates the JideTabbedPane is null in the UI, it might relate to how Netbeans repaint the UI on editing. It's always a shaky part and I would recommend you to write the code for JideTabbedPane for now. The screen cast of the my test in XP is uploaded at http://screencast.com/t/ERFHk5Tw FYI.
Postby andrednasoftware » Wed Oct 05, 2011 5:19 am
Thank you.
For now I will use this way.
If there is anything I can do to help solve the problem, contact me.
andrednasoftware
