CheckBoxTree and TreeSelectionListener
Postby Reyada Wolak » Wed Aug 10, 2011 11:19 pm
I'm trying to get one event when selecting a box containing all the selected paths after clicking. TreeSelectionListener is always returning two events (add,remove in order) by default. Using setSingleEventMode(true) will through many events not one event.
CheckBoxTree.getCheckBoxTreeSelectionModel().addTreeSelectionListener(new TreeSelectionListener()
            public void valueChanged(TreeSelectionEvent e)
Is there a way to make "remove event" before "add event". The reason is that I'm trying to manipulate a data structure and "remove even" is removing some nodes from the parent node even thought the parent is selected i.e. is i have this structure:
a--
|-b
|-c
a,b are selected
if you select c, "add event" will add the path "a" then "remove event" will remove "a-b". i have data structure that is adding/removing with any change in the tree. with this order the data for "a-b" will be lost even though it is selected.
i'm using the latest version 3.1.1
Reyada Wolak
Re: CheckBoxTree and TreeSelectionListener
Postby JIDE Support » Thu Aug 11, 2011 9:07 am
Thanks for bug report. Will fix it in later release. Please rely on CheckBoxTreeSelectionModel#getSelectionPaths() for now to take actions as a workaround in current release.
Postby JIDE Support » Thu Sep 29, 2011 9:45 pm
Just so you know, this is fixed in 3.2.3 just released.
Postby Reyada Wolak » Sat Oct 01, 2011 10:29 pm
many thanks.
still setSingleEventMode(true) results in firing many events.
Reyada Wolak
Postby JIDE Support » Mon Oct 03, 2011 2:38 pm
Will fix that issue in next regular release.
Postby JIDE Support » Fri Oct 21, 2011 3:53 pm
Just so you know, this is fixed in 3.2.4 just released.
Postby Reyada Wolak » Sun Oct 23, 2011 12:48 am
many thanks. it works great
Reyada Wolak
