by JSchaefer » Sun Jul 03, 2011 10:34 am
Hello together,
i am new in JIDE and want to explore the GroupTableDemo.
This Demo use the CalculatedTableModel Class.
I cant find this class.I looked in the Javadoc and found it under com.jidesoft.grid.CalculatedTableModel.
But it is not possible to import.
I use Eclipse with java SE 1.6 and Jide 3.1.0 eval.
I referenced only the necessary Lib!
Any suggestions?
Thanks Jürgen
JSchaefer
by JIDE Support » Mon Jul 04, 2011 6:55 am
The class is inside jide-pivot.jar instead of jide-grids.jar.
by JSchaefer » Tue Jul 05, 2011 12:41 pm
Thank a lot. But that means also that I have to buy the Pivot extension to use the CalculatedTableModel?
I find that model realy usefull also without the pivot.jar.
Greetings Jürgen
JSchaefer
by JIDE Support » Tue Jul 05, 2011 1:12 pm
Even though it is in jide-pivot.jar, you should still able to use it as long as you have a valid license key for JIDE Grids.
