How to maintain the order and the size of the column
Postby sarikap08 » Mon Jun 27, 2011 10:57 pm
I have a below requirement:
"The user can change the order, the size of the columns in Table.
If the user clicks on the button search, the size, sort out, order of the columns will not be lost."
For this I am using SortableTable and setting the Table model which is extending DefaultTable model and that table model is setting by calling
SortableTable table=new sortableTable(model);
In that way ,I am able to sort the data by cliking on the particular column but not able to maintain the order of the column i.e if I move few columns by using mouse and click on Search, the order of the column get reached to its intial position.
Please help me out.
Thanks in adavance
sarikap08
Re: How to maintain the order and the size of the column
Postby JIDE Support » Tue Jun 28, 2011 8:54 am
Can you please what "Search" is in your context? Is it a QuickFilterField or AutoFilterTableHeader or just a button? If it's a button, will its action listener fire table structure change event for some reason?
Postby sarikap08 » Tue Jun 28, 2011 10:19 am
It's just a search button and I am not firing any table structure change event
sarikap08
Postby JIDE Support » Tue Jun 28, 2011 10:48 am
Could you please tell us what exactly the search button does? if you can share us the code of this search button action, it would be great.
