Jide GroupTable
Jide GroupTable
Postby robertho21 » Wed Jun 01, 2011 11:12 am
We are already a client using your product, I'm testing GroupTable but I can't find how to show the table header in order to set visible "Drag columns here to group".
I have already set:
_table.getTableHeader().setEnabled(true);
_table.getTableHeader().setVisible(true);
Could you tell me what am I missing ??
robertho21
Re: Jide GroupTable
Postby JIDE Support » Wed Jun 01, 2011 11:30 am
Please give the following code a try.
        GroupTableHeader header = new GroupTableHeader(_table);
        _table.setTableHeader(header);
        header.setGroupHeaderEnabled(true);
Re: Jide GroupTable
Postby robertho21 » Wed Jun 01, 2011 12:28 pm
Hi, thanks for you reply, but our JIDE Library doesn't have GroupTableHeader class, could you tell me the version of the JIDE GRIDS, that I need to use.
Robertho.
robertho21
Re: Jide GroupTable
Postby JIDE Support » Wed Jun 01, 2011 1:03 pm
It was introduced since 2.11.0. Please give the latest release a try.
Re: Jide GroupTable
Postby robertho21 » Wed Jun 01, 2011 2:29 pm
Thanks, I have updated the jar and now I can see the class.
I'm following your example of GroupTableDemo with my data, but I'm getting an exception when I try to do the next task:
_groupTableModel = new StyledGroupTableModel(calculatedTableModel);
_groupTableModel.addGroupColumn(0, DefaultGroupTableModel.SORT_GROUP_COLUMN_ASCENDING);
Exception...
Exception in thread "main" java.lang.NoSuchMethodError: com.jidesoft.grid.DefaultGroupTableModel.addGroupColumn(II)V
at com.rob.GroupTableDemo.getDemoPanel(GroupTableDemo.java:210)
at com.rob.GroupTableDemo.<init>(GroupTableDemo.java:167)
at com.rob.GroupTableDemo.main(GroupTableDemo.java:162)
Could you tell what I'm doing wrong.
robertho21
Re: Jide GroupTable
Postby JIDE Support » Wed Jun 01, 2011 2:40 pm
Please check your class path to make sure any older JIDE jars are excluded in the class path for sure.
Re: Jide GroupTable
Postby robertho21 » Thu Jun 02, 2011 6:52 am
Now is working perfect, thanks.
robertho21
