by gokulanand » Mon May 23, 2011 6:41 am
Hello Team,
I was going through DateComboBoxDemo from JIDE examples. With the "WeekDayOnly" datefilter, I could see only the weekdays are enabled and weekends are disabled. This means the user will not be able to select Weekend dates at all.
All I wanted is to differentiate weekdays from weekends ( with the help of "WeekdayOnly" dateFilter ) and also user should be able to pick any day of his wish ( including weekends ). Is that possible to do this ?
gokulanand
by JIDE Support » Mon May 23, 2011 8:45 am
Please use the following code to override DateComboBox.
- Code: Select all
new DateComboBox() {
protected DateChooserPanel createDateChooserPanel() {
return new DateChooserPanel(getDateModel(), isShowTodayButton(), isShowNoneButton(), isShowWeekNumbers(), getLocale()) {
protected void updateDateLabel(JComponent dateLabel, Calendar date, boolean isSelected, boolean isToday, boolean withinCurrentMonth) {
super.updateDateLabel(dateLabel, date, isSelected, isToday, withinCurrentMonth);
if (isHoliday(date)) { // take your logic to decide which date you want to change color
dateLabel.setOpaque(true);
((JideButton) dateLabel).setBackgroundOfState(ThemePainter.STATE_DEFAULT, Color.gray);
by gokulanand » Mon May 23, 2011 11:54 pm
Great. It worked. Thanks a lot.
gokulanand
by onlyhuman » Thu Jul 17, 2014 1:02 am
I've used this code to disable weekday labels and it is working for a single click, but for double clicks it is still selecting a weekday. I've tried to add a mouse listener to dateLabel and consume it when clickCount was 2, but it did not work. Do you have any idea how can I omit double clicks?
Thanks in advance!
Best regards,
Robert
onlyhuman
by JIDE Support » Thu Jul 17, 2014 8:57 am
I am not quite sure. If you override createDateLabel to create your own label and add your own mouse listener, double click shouldn't handled. Could you try to reproduce it by making a simple test case so that I can compile and run?
by onlyhuman » Mon Feb 16, 2015 1:23 am
Sorry for the late reply, here is a sample code that you can compile. I did not add a mouse listener to consume double clicks but it is not working in this way either. I am using JIDE version 2.4.5
- Code: Select all
package test;
import java.awt.BorderLayout;
import java.awt.Color;
import java.util.Calendar;
import javax.swing.BorderFactory;
import javax.swing.JComponent;
import com.jidesoft.combobox.DateChooserPanel;
import com.jidesoft.combobox.DateComboBox;
import com.jidesoft.plaf.basic.ThemePainter;
import com.jidesoft.swing.JideButton;
public class DateComboboxTestMain extends JPanel {
private final class DateComboBoxExtension extends DateComboBox {
private static final long serialVersionUID = 1L;
public com.jidesoft.combobox.PopupPanel createPopupComponent() {
if (isDateOnDay(date, Calendar.MONDAY) || isDateOnDay(date, Calendar.SUNDAY)) {
((JideButton) dateLabel).setBackgroundOfState(ThemePainter.STATE_DEFAULT, Color.lightGray);
((JideButton) dateLabel).setEnabled(false);
private boolean isDateOnDay(Calendar date, int dow) {
int dayOfWeek = date.get(Calendar.DAY_OF_WEEK);
return dayOfWeek == dow;
private DateComboBoxExtension dateCombo = new DateComboBoxExtension();
public DateComboboxTestMain() {
add(dateCombo, BorderLayout.PAGE_START);
setBorder(BorderFactory.createEmptyBorder(20, 20, 20, 20));
// Schedule a job for the event-dispatching thread:
// creating and showing this application's GUI.
javax.swing.SwingUtilities.invokeLater(new Runnable() {
public void run() {
createAndShowGUI();
private static void createAndShowGUI() {
JFrame frame = new JFrame("DateComboboxDemo");
JComponent newContentPane = new DateComboboxTestMain();
newContentPane.setOpaque(true);
frame.setContentPane(newContentPane);
frame.pack();
onlyhuman
