add MultiplePageDialogPane into JPanel
Postby gokulanand » Fri Apr 29, 2011 4:21 am
I created a MultiplePageDialogPane and added it to a panel. But I couldnt see the multiplePageDialogPane in my screen. I used JPanel#add() function to add multiplePageDialogPane.
Here is how I created multiplePageDialogPane
1) Created a multiplePageDialogPane object with LIST_STYLE.
2) Created few AbstractDialogPage objects and added it to a PageList. ( using PageList#append() )
3) Set the page list to multiplePageDialogPane.
It would be great if some one helps me in this. Also let me know if I am missing something.
Gokul
gokulanand
Re: add MultiplePageDialogPane into JPanel
Postby JIDE Support » Fri Apr 29, 2011 10:01 am
Please give the following test case a try.
IntelliJOptionsPane.java
(7.35 KiB) Downloaded 2208 times
Postby gokulanand » Sun May 01, 2011 10:40 pm
Thanks mate. It worked
gokulanand
