Look and feel extensions mess up application menu
Postby JohnnyK » Mon Apr 11, 2011 8:43 am
I am currently trying out the Searchable feature. Although this is working fine, I observed that the JIDE look and feel extensions are automatically applied when the feature is used. This has some drawbacks regarding the applications menu:
- Before look and feel extensions have been applied
Application menu before using Searchable
- After look and feel extensions have been applied
Application menu after using Searchable
Is this behaviour desired?
Some information that might help to reproduce my issue:
  • Version: 2.11.2
  • Look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
  • OS: Windows Vista
Thanks in advance,
- Thomas
LookAndFeelExtension.java
Source code
(2.51 KiB) Downloaded 12710 times
JohnnyK
Re: Look and feel extensions mess up application menu
Postby JIDE Support » Mon Apr 11, 2011 9:11 am
We have to install JIDE extensions for JIDE components. Please use the following code to avoid the drawback.
    private static void setLookAndFeel() {
            UIManager.setLookAndFeel("com.sun.java.swing.plaf.windows.WindowsLookAndFeel");
        } catch (Exception e) {
            e.printStackTrace();
//            ignore
        LookAndFeelFactory.installJideExtension(LookAndFeelFactory.VSNET_STYLE_WITHOUT_MENU);
Postby JohnnyK » Tue Apr 12, 2011 3:56 am
Thank you very much, with this code snippet it works like a charm.
- Thomas
JohnnyK
Postby jschlade » Wed Nov 02, 2016 9:13 am
Is there anyway to keep the default color of tabs when using JideTabbedPane and use the default black/grey menu color when using the default L&Fs on Windows 7? Using Java 1.8.
When I use LookAndFeelFactory.installJideExtension(LookAndFeelFactory.VSNET_STYLE_WITHOUT_MENU) I keep the menu coloring I want but the tab color goes disappears.
jschlade
Postby td84 » Thu Nov 03, 2016 3:37 pm
i noticed, if i use any of the JIDE component, there will be always a checkmark in front of a Jmenu element, like on the image for the Jmenuitem "Import".
If there is no JIDE component in my project, then there is no checkmark.
Is ther a way to remove entirely this checkmark?
Thanx,
Daniel
td84
Postby jschlade » Fri Nov 04, 2016 12:34 am
Need to call LookAndFeelFactory.installJideExtension(LookAndFeelFactory.VSNET_STYLE_WITHOUT_MENU). See javadoc for more info.
jschlade
Postby td84 » Tue Nov 22, 2016 7:17 am
jschlade wrote:Need to call LookAndFeelFactory.installJideExtension(LookAndFeelFactory.VSNET_STYLE_WITHOUT_MENU). See javadoc for more info.
Thanx. Now it works great.
td84
Users browsing this forum: No registered users and 108 guests
