ScrollPaneOverview example
Postby Maurice » Tue Mar 22, 2011 10:05 am
I would like to create a panel with a JTable and a permanent ScrollPaneOverview on the side of the table. I am having some problems and could not find an example on the DEMO examples.
I am trying to do the following:
        JideScrollPane scrollpane = new JideScrollPane();
        scrollpane.setViewportView(table);
        scrollpane.setHorizontalScrollBarCoversWholeWidth(true);
        scrollpane.setVerticalScrollBarCoversWholeHeight(true);
        JPanel panel = new JPanel();
        final ScrollPaneOverview scrollPaneOverview = new ScrollPaneOverview(scrollpane, panel);
        scrollPaneOverview.setPreferredSize(new Dimension(100, 100));
        panel.setPreferredSize(new Dimension(100, 100));
        panel.add(scrollPaneOverview);
        add(scrollpane, BorderLayout.CENTER);
        add(panel, BorderLayout.WEST);
   scrollPaneOverview.display();
Any tips or even an example would be appreciated.
Many Thanks.
Maurice
Re: ScrollPaneOverview example
Postby JIDE Support » Tue Mar 22, 2011 10:35 am
Can you please elaborate the issue you are having? Basically we would recommend you use a JButton as ScrollPaneOverview's owner and call display() on action listener of the button.
Postby Maurice » Wed Mar 23, 2011 2:14 am
I am trying to add the overview to a JPanel which will sit next to the table being viewed.
The problem I am having is that I would like to have a permanent view of the table in an overview panel, which users can then use to move themselves around what is a large data set.
I don't want the user to have to click a button to do this. However, when I use the code below nothing is displayed.
Many Thanks
Maurice
Postby JIDE Support » Wed Mar 23, 2011 11:32 am
I'm afraid ScrollPaneOverview does not fit your request very well. As you can see from the source code, on displaying, it will show a popup. The reason you didn't see any is that, the popup is hidden on focus change later on. You may have to create your own component to achieve your goal.
