HierarchicalTable display failure
Postby si031006 » Wed Mar 02, 2011 6:58 am
I am new to JIDE, so I have a question about HierarchicalTable:
I programmed a class which extends HierarchicalTable and when expanded, another Table is displayed. This worked well, but there is still a little problem.
When expanded, the new Table is not UNDER, it is BEFORE the expanded row (see the screenshot in falseDisplay.jpg).
In fact, my wish is to display the new Table (when expanded) UNDER the selected row. Anyone an idea about this?
thx in advance
si031006
Re: HierarchicalTable display failure
Postby JIDE Support » Wed Mar 02, 2011 11:02 am
Can you please share with us a test case? Just tried JIDE HierachicalTableDemo in 2.11.1 and it works fine for me.
Postby si031006 » Thu Mar 03, 2011 12:32 am
Sure, here it is.
Here is my HierarchicalTableComponentFactory:
public class JIDEHierarchicalTableComponentFactory implements HierarchicalTableComponentFactory {
    private QueryGeneral            query      = null;
    private Connection              connection = null;
    private ListSelectionModelGroup group      = null;
    public JIDEHierarchicalTableComponentFactory(Connection conn, QueryGeneral query) {
        this.connection=conn;
        this.query=query;
        this.group=new ListSelectionModelGroup();
    }//JIDEHierarchicalTableComponentFactory
    public Component createChildComponent(HierarchicalTable table, Object value, int row) {
        if (value == null)
            return new JPanel();
        int[] valueNew=(int[])value;
        if (valueNew.length<=0)
            HirarchicalTable childTable = new HirarchicalTable(this.connection, this.query.getChildQuery());
            childTable.setChildData(true, this.query,table,row);
            FitScrollPane pane=new FitScrollPane(childTable.getTable());
            TreeLikeHierarchicalPanel treeLikeHierarchicalPanel = new TreeLikeHierarchicalPanel(pane);
            return treeLikeHierarchicalPanel;
        } catch (SQLException ex) {
            ReportingLogger.getInstance().writeErrorReporting("JIDEHierarchicalTableComponentFactory", "createChildComponent", ex);
    }//createChildComponent
     public void destroyChildComponent(HierarchicalTable table, Component component, int row) {
        //System.out.println("Destroy:"+component);
     }//destroyChildComponent
class FitScrollPane extends JScrollPane implements ComponentListener {
        public FitScrollPane() {
            initScrollPane();
        public FitScrollPane(Component view) {
            super(view);
            initScrollPane();
        public FitScrollPane(Component view, int vsbPolicy, int hsbPolicy) {
            super(view, vsbPolicy, hsbPolicy);
            initScrollPane();
        public FitScrollPane(int vsbPolicy, int hsbPolicy) {
            super(vsbPolicy, hsbPolicy);
            initScrollPane();
        private void initScrollPane() {
            setBorder(BorderFactory.createLineBorder(Color.GRAY));
            setHorizontalScrollBarPolicy(JScrollPane.HORIZONTAL_SCROLLBAR_NEVER);
            setVerticalScrollBarPolicy(JScrollPane.VERTICAL_SCROLLBAR_NEVER);
            getViewport().getView().addComponentListener(this);
            removeMouseWheelListeners();
        // remove MouseWheelListener as there is no need for it in FitScrollPane.
        private void removeMouseWheelListeners() {
            MouseWheelListener[] listeners = getMouseWheelListeners();
            for (MouseWheelListener listener : listeners) {
                removeMouseWheelListener(listener);
        public void updateUI() {
            super.updateUI();
        public void componentResized(ComponentEvent e) {
            setSize(getSize().width, getPreferredSize().height);
        public void componentMoved(ComponentEvent e) {
        public void componentShown(ComponentEvent e) {
        public void componentHidden(ComponentEvent e) {
        public Dimension getPreferredSize() {
            getViewport().setPreferredSize(getViewport().getView().getPreferredSize());
            return super.getPreferredSize();
Here is the class which tells if there are child Tables and when which columns to handle:
public class QueryGeneral {
    private String   masterTableName   = null;
    private String[] masterTableFields = null;
    private String       childTableName    = null;
    private String[]     childTableFields  = null;
    private QueryGeneral childQuery        = null;
    private boolean      hasChild          = false;
    private boolean      childIsQuery      = false;
    private String[] masterTableFieldsForChild=null;
    private String[] childTableFieldsForMaster=null;
    private int[]    masterTableFieldsForChildIndex=null;
    private int[]    childTableFieldsForMasterIndex=null;
    public QueryGeneral(String tableName) {
        this.masterTableName=tableName;
        this.masterTableFields=new String[]{"*"};
        this.hasChild=false;
        this.childIsQuery=false;
        this.childTableName=null;
        this.childTableFields=ArrayUtils.EMPTY_STRING_ARRAY;
        this.childQuery=null;
        this.masterTableFieldsForChild=ArrayUtils.EMPTY_STRING_ARRAY;
        this.childTableFieldsForMaster=ArrayUtils.EMPTY_STRING_ARRAY;
        this.masterTableFieldsForChildIndex=ArrayUtils.EMPTY_INT_ARRAY;
        this.childTableFieldsForMasterIndex=ArrayUtils.EMPTY_INT_ARRAY;
     * @return the masterTableName
    public String getMasterTableName() {
        return masterTableName;
     * @param masterTableName the masterTableName to set
    public void setMasterTableName(String masterTableName) {
        this.masterTableName = masterTableName;
     * @return the masterTableFields
    public String[] getMasterTableFields() {
        return masterTableFields;
     * @param masterTableFields the masterTableFields to set
    public void setMasterTableFields(String[] masterTableFields) {
        this.masterTableFields = masterTableFields;
     * @return the childTableName
    public String getChildTableName() {
        return childTableName;
     * @param childTableName the childTableName to set
    public void setChildTableName(String childTableName) {
        this.childTableName = childTableName;
     * @return the childTableFields
    public String[] getChildTableFields() {
        return childTableFields;
     * @param childTableFields the childTableFields to set
    public void setChildTableFields(String[] childTableFields) {
        this.childTableFields = childTableFields;
     * @return the childQuery
    public QueryGeneral getChildQuery() {
        return childQuery;
     * @param childQuery the childQuery to set
    public void setChildQuery(QueryGeneral childQuery) {
        this.childQuery = childQuery;
        if (childQuery==null) {
        else {
            this.childIsQuery=true;
            this.hasChild=true;
     * @return the hasChild
    public boolean isHasChild() {
        return hasChild;
     * @param hasChild the hasChild to set
    public void setHasChild(boolean hasChild) {
        this.hasChild = hasChild;
        if (this.hasChild==false) {
     * @return the childIsQuery
    public boolean isChildIsQuery() {
        return childIsQuery;
     * @param childIsQuery the childIsQuery to set
    public void setChildIsQuery(boolean childIsQuery) {
        this.childIsQuery = childIsQuery;
        if (childIsQuery==false)
     * @return the masterTableFieldsForChild
    public String[] getMasterTableFieldsForChild() {
        return masterTableFieldsForChild;
     * @param masterTableFieldsForChild the masterTableFieldsForChild to set
    public void setMasterTableFieldsForChild(String[] masterTableFieldsForChild) {
        this.masterTableFieldsForChild = masterTableFieldsForChild;
     * @return the childTableFieldsForMaster
    public String[] getChildTableFieldsForMaster() {
        return childTableFieldsForMaster;
     * @param childTableFieldsForMaster the childTableFieldsForMaster to set
    public void setChildTableFieldsForMaster(String[] childTableFieldsForMaster) {
        this.childTableFieldsForMaster = childTableFieldsForMaster;
     * @return the masterTableFieldsForChildIndex
    public int[] getMasterTableFieldsForChildIndex() {
        return masterTableFieldsForChildIndex;
     * @param masterTableFieldsForChildIndex the masterTableFieldsForChildIndex to set
    public void setMasterTableFieldsForChildIndex(int[] masterTableFieldsForChildIndex) {
        this.masterTableFieldsForChildIndex = masterTableFieldsForChildIndex;
     * @return the childTableFieldsForMasterIndex
    public int[] getChildTableFieldsForMasterIndex() {
        return childTableFieldsForMasterIndex;
     * @param childTableFieldsForMasterIndex the childTableFieldsForMasterIndex to set
    public void setChildTableFieldsForMasterIndex(int[] childTableFieldsForMasterIndex) {
        this.childTableFieldsForMasterIndex = childTableFieldsForMasterIndex;
Here the class which makes the HierarchicalTable
(uses the method setMasterChildDetail() for details about Master-Child).
It uses the DataTableModel. Example of that is also available later in this Thread.
public class DataTableJIDE extends HierarchicalTable {
    private AutoFilterTableHeader header      = null;
    private QueryGeneral          queryMaster = null;
    private JTable                masterTable = null;
    private int                   queryRow    = -1;
    private boolean               applyFilter = false;
    public DataTableJIDE(Connection conn, QueryGeneral query) throws SQLException {
        super(new DataTableJIDETableModel(conn,query));
        this.query=query;
        this.queryMaster=null;
        this.applyFilter=false;
        this.setAutoResizeMode(JTable.AUTO_RESIZE_OFF); //notwendig für horizontalen Scrollbalken
        this.setClickCountToStart(100);
        //this.setClickCountToStart(2); //Anzahl der Tastedrücke für
        this.setColumnSelectionAllowed(false);
        this.setAutoFilter(true);
        this.setMasterChildDetail();
        //this.setRowResizable(true);
        //this.setTableStyleProvider(new RowStripeTableStyleProvider());
        this.createFilter();
    public void setMasterChildDetail() {
        this.setComponentFactory(new JIDEHierarchicalTableComponentFactory(this.connection,this.query));
    public void createFilter() {
        if (this.applyFilter==false) return;
        if (this.queryMaster==null) return;
        if (this.masterTable==null) return;
        if (this.queryRow<0) return;
        DataTableJIDETableModel model=((DataTableJIDETableModel)this.getModel());
        String[] childFields=this.queryMaster.getChildTableFieldsForMaster();
        int[]    masterFieldIndex=this.queryMaster.getMasterTableFieldsForChildIndex();
        int[]    childFieldIndex=model.fillColumnDataIndex(this.queryMaster.getChildTableFieldsForMaster());
        for(int i=0;i<childFields.length;i++) {
            Filter filter=new EqualFilter(this.masterTable.getValueAt(this.queryRow, masterFieldIndex[i]));
            model.addFilter(childFieldIndex[i],filter);
        }//for(i)
        model.refresh();
    }//setFilter
    public void setAutoFilter(boolean enabled) {
       if (enabled==true) {
           AutoFilterTableHeader header1=new AutoFilterTableHeader(this);
           header1.setAutoFilterEnabled(true);
           //header.setAcceptTextInput(true);
           header1.setShowFilterIcon(true);
           header1.setAllowMultipleValues(false);
           header1.setShowFilterName(true);
           this.setTableHeader(header1);
           TableHeaderPopupMenuInstaller installer = new TableHeaderPopupMenuInstaller(this);
           installer.addTableHeaderPopupMenuCustomizer(new AutoResizePopupMenuCustomizer());
           installer.addTableHeaderPopupMenuCustomizer(new TableColumnChooserPopupMenuCustomizer());
       else {
           this.setAutoFilter(false);
    }//setAutoFilter
     * @return the applyFilter
    public boolean isApplyFilter() {
        return applyFilter;
     * @param applyFilter the applyFilter to set
    public void setApplyFilter(boolean applyFilter) {
        this.applyFilter = applyFilter;
     * @return the queryMaster
    public QueryGeneral getQueryMaster() {
        return queryMaster;
     * @param queryMaster the queryMaster to set
    public void setQueryMaster(QueryGeneral queryMaster) {
        this.queryMaster = queryMaster;
    public JTable getMasterTable() {
        return masterTable;
     * @param masterTable the masterTable to set
    public void setMasterTable(JTable masterTable) {
        this.masterTable = masterTable;
     * @return the queryRow
    public int getQueryRow() {
        return queryRow;
     * @param queryRow the queryRow to set
    public void setQueryRow(int queryRow) {
        this.queryRow = queryRow;
And finally here the DatabaseTableModel used by the Hierarchical Table:
public class DataTableJIDETableModel extends DatabaseTableModel implements HierarchicalTableModel {
    public DataTableJIDETableModel(Connection conn,QueryGeneral query) throws SQLException {
        super(conn,query.getMasterTableName());
        this.query=query;
        this.fillMasterChildData();
    public boolean hasChild(int arg0) {
        return (this.query.getMasterTableFieldsForChildIndex().length>=0)?true:false;
    public boolean isHierarchical(int arg0) {
    public Object getChildValueAt(int arg0) {
        return this.query.getMasterTableFieldsForChildIndex();
    public boolean isExpandable(int arg0) {
        return this.hasChild(arg0);
    private void fillMasterChildData() {
        if (query.isHasChild()==false) return;
        int[] queryIndexMaster=ArrayUtils.EMPTY_INT_ARRAY;
        String[] masterFields=query.getMasterTableFieldsForChild();
        for(int i=0;i<this.getColumnCount();i++) {
            for(int i1=0;i1<masterFields.length;i1++) {
                if (masterFields[i1].equalsIgnoreCase(this.getColumnName(i))==true) {
                    queryIndexMaster=ArrayUtils.add(queryIndexMaster,i);
                }//if(Name==masterFields)
            }//for(i1)
        }//for(i)
        this.query.setMasterTableFieldsForChildIndex(queryIndexMaster);
    }//fillMasterChildData
    public int[] fillColumnDataIndex(String[] columnNames) {
        int[] queryIndex=new int[columnNames.length];
            for(int i1=0;i1<columnNames.length;i1++) {
                if (columnNames[i1].equalsIgnoreCase(this.getColumnName(i))==true) {
                    queryIndex[i1]=i;
                }//if(Name==columnNames)
            }//for(i1)
        }//for(i)
        return queryIndex;
si031006
Postby JIDE Support » Thu Mar 03, 2011 4:04 pm
Can you please share with us a stand-alone runnable test case? Appreciate all the input but I still could not make it run.
Postby si031006 » Fri Mar 04, 2011 8:25 am
General:
I user following libaries for this classes:
- jide-data.jar
- jide-grids.jar
- commons-lang-2.5.jar (Apache commonIO project for using Arrays)
- slqjdbc4.jar (driver for MS-SQL)
Also I used a MS-SQL Server 2008 (R2) for connection and I didnt use a table, I used views for the master/detail tables...
Okay, just start with this class (just copy/past and rename the package):
package versuche;
import versuche.QueryGeneral.*;
import org.apache.commons.lang.ArrayUtils;
        return childQuery;
        else {
            this.hasChild=true;
        return hasChild;
Here comes the TableModel (also just copy/paste) and renaming of the packages:
package versuche;
import com.jidesoft.database.DatabaseTableModel;
import com.jidesoft.filter.Filter;
import com.jidesoft.grid.HierarchicalTableModel;
import java.sql.Connection;
import java.sql.SQLException;
    private Filter[]     filterGeneral        = null;
    private int[]        filterGeneralColumns = null;
        this.query=query;
        this.filterGeneralColumns=ArrayUtils.EMPTY_INT_ARRAY;
            }//for(i1)
        }//for(i)
                    queryIndex[i1]=i;
            }//for(i1)
        }//for(i)
        return queryIndex;
    }//fillColumnDataIndex
    public void createChildFilter() {
        this.setFiltersApplied(false);
        for(int i=0;i<this.filterGeneralColumns.length;i++) {
            this.setFiltersApplied(true);
            this.addFilter(this.filterGeneralColumns[i],this.filterGeneral[i]);
        }//for(i)
        this.refresh();
    }//createChildFilter
    public void setFilterGeneral(int[] filterIndex, Filter[] filterGeneral) {
        this.filterGeneralColumns=filterIndex;
        this.filterGeneral=filterGeneral;
    }//setFilterGeneral
Here is my implementation of the HierarchicalTableComponentFactory. Also just copy and paste.
package versuche;
import com.jidesoft.filter.EqualFilter;
import com.jidesoft.grid.HierarchicalTable;
import com.jidesoft.grid.HierarchicalTableComponentFactory;
import com.jidesoft.grid.ListSelectionModelGroup;
import com.jidesoft.grid.TreeLikeHierarchicalPanel;
import java.awt.Color;
import java.awt.Component;
import java.awt.Dimension;
import java.awt.event.ComponentEvent;
import java.awt.event.ComponentListener;
import java.awt.event.MouseWheelListener;
import javax.swing.BorderFactory;
        this.query=query;
        System.out.println("Opening child mit value:"+value);
        if (value == null)
            String   filterName = "GENERALCHILDFILTER";
            Filter[] filter = null;
            int[]    index  = ArrayUtils.EMPTY_INT_ARRAY;
            DataTableJIDETableModel model=(DataTableJIDETableModel)childTable.getTable().getModel();
            int[] fieldsMaster=this.query.getMasterTableFieldsForChildIndex();
            int[] fieldsChild=model.fillColumnDataIndex(this.query.getChildTableFieldsForMaster());
            for(int i=0;i<fieldsMaster.length;i++) {
                Object valueMaster=table.getValueAt(row, fieldsMaster[i]);
                filter=(Filter[])ArrayUtils.add(filter,new EqualFilter(filterName,valueMaster));
                index=ArrayUtils.add(index, fieldsChild[i]);
            }//for(i)
            model.setFilterGeneral(index, filter);
            model.createChildFilter();
        } catch (Exception ex) {
            initScrollPane();
            super(view);
            initScrollPane();
            initScrollPane();
            initScrollPane();
            super.updateUI();
Then the table itself. Should be no problem, just renaming the real packages:
package versuche;
import com.jidesoft.grid.AutoFilterTableHeader;
import com.jidesoft.grid.AutoResizePopupMenuCustomizer;
import com.jidesoft.grid.RowStripeTableStyleProvider;
import com.jidesoft.grid.TableColumnChooserPopupMenuCustomizer;
import com.jidesoft.grid.TableHeaderPopupMenuInstaller;
import java.awt.event.MouseAdapter;
import java.awt.event.MouseEvent;
import java.awt.event.MouseListener;
import javax.swing.JTable;
    private QueryGeneral          queryGeneral= null;
        this.queryGeneral=query;
        //this.setAutoFilter(true);
        this.setComponentFactory(new JIDEHierarchicalTableComponentFactory(this.connection,this.queryGeneral));
           header1.setAllowMultipleValues(true);
       else {
    }//setAutoFilter
Here ist a superclass for Hirarchical Tables. I used this to switch between some table classes...
package versuche;
public class HirarchicalTable {
    private JTable     table  = null;
    public HirarchicalTable(Connection conn, QueryGeneral query) throws SQLException {
        this.table=new DataTableJIDE(conn,query);
    public JTable getTable() {
        return this.table;
And finally the main class.
Here you have to insert the name of the master/detail table and the connectionfields between these two.
package versuche;
import java.awt.Frame;
import java.sql.DriverManager;
public class Main {
     * @param args the command line arguments
            String masterTable="<NAME OF THE MASTER TABLE/VIEW>";
            String detailTable="<NAME OF THE DETAIL TABLE/VIEW>";
            String[] masterFieldsJoinWithChild={"<FIELD(S) IN MASTERTABLE WITH CONNECTION TO CHILD TABLE>"};
            String[] childFieldsJoinWithMaster={"<FIELD(S) IN CHILDTABLE WITH CONNECTION TO MASTER TABLE>"};
            System.out.println("Registering driver");
            Class.forName("com.microsoft.sqlserver.jdbc.SQLServerDriver");
            System.out.println("Trying to open the Database...");
            connection = DriverManager.getConnection("<HERE THE CONNECTION STRING>");
            System.out.println("Database opened...");
            System.out.println("Set Master-Detail Query...");
            QueryGeneral master=new QueryGeneral(masterTable);
            master.setChildTableName(detailTable);
            master.setChildTableFieldsForMaster(childFieldsJoinWithMaster);
            master.setMasterTableFieldsForChild(masterFieldsJoinWithChild);
            QueryGeneral detail=new QueryGeneral(detailTable);
            master.setChildQuery(detail);
            System.out.println("Opening Hirarchical Table..");
            JTable table=new HirarchicalTable(connection,master).getTable();
            JFrame frame=new JFrame("TEST");
            frame.setExtendedState(Frame.MAXIMIZED_BOTH);
            JScrollPane pane=new JScrollPane(table);
            frame.add(pane);
        }catch(Exception ex) {
            try{connection.close();} catch(Exception ex1) {System.out.println("Failure when closing:"+ex1);}
            System.out.println("Failure:"+ex);
si031006
Postby si031006 » Fri Mar 04, 2011 8:33 am
STOP:
Found my failure.
the isHierarchical method should be set to TRUE, then it works correctly....
Sorry for my question!!!
si031006
