by Reyada Wolak » Mon Feb 21, 2011 11:15 pm
I have tried custom L&F with RangeSlider.putClientProperty("JSlider.isFilled", Boolean.TRUE);
but it is not giving me the correct color for the custom L&F. it gives me the color for metal.
any hints.
Reyada Wolak
by JIDE Support » Wed Feb 23, 2011 3:34 pm
To make this client property effective in other custom L&F, you have to create your customized SliderUI class and paint the filler as MetalSliderUI does. You could override BasicSliderUI#paintTrack() to achieve your goal.
by Reyada Wolak » Wed Feb 23, 2011 11:03 pm
thanks for the info
i guess it is more complicated than i though. i will try to achieve the same functionality in different way.
Reyada Wolak
