Searchable w/timeout
Postby sbrattla » Wed Jan 26, 2011 2:58 am
I needed the Searchable pop up to hide after a given number of miliseconds, so I extended ListSearchable
and wrote a few lines of code which takes care of it. If anyone else needs this functionality, then feel
free to use the below code. I haven't put too much effort in documenting the code, but it is fairly self
explanatory so you shouldn't have too much trouble reading it if you need to make any adjustments.
Usage:
JList l = new JList();
ListSearchable lS = new ListSearchableWithTimeOut(l, 350);
The ListSearchableWithTimeOut has two constructors. One which accepts the JList which is to be made
searchable (and which hides the searchable pop up after 350 miliseconds) and one which accepts the JList along
with the delay specified in miliseconds.
package com.tracker.utilities.swing.components;
import com.jidesoft.swing.ListSearchable;
import com.jidesoft.swing.event.SearchableEvent;
import com.jidesoft.swing.event.SearchableListener;
import java.util.Timer;
import java.util.TimerTask;
import javax.swing.JList;
public class ListSearchableWithTimeOut extends ListSearchable {
    private final int delay;
    private TimerTask task;
    private Timer timer;
    public ListSearchableWithTimeOut(JList list) {
        this(list, 350);
    public ListSearchableWithTimeOut(JList list, int delay) {
        super(list);
        this.delay = delay;
        initialise();
    private void initialise() {
        timer = new Timer();
        addSearchableListener(new SearchableListener() {
            public void searchableEventFired(SearchableEvent evt) {
                if (task != null) {
                    task.cancel();
                task = new HideTask();
                timer.schedule(task, delay);
    private ListSearchable getListSearchable() {
        return this;
    private class HideTask extends TimerTask {
        public void run() {
            getListSearchable().hidePopup();
sbrattla
Re: Searchable w/timeout
Postby Walter Laan » Wed Jan 26, 2011 4:25 am
That's a really nice idea!
Your implementation ignores the EDT so perhaps Jide could add the following to SearchableUtils using javax.swing.Timer (or make it a method of Searchable itself). I think java.net is still in migration lock down so can't be committed atm.
public static void installPopupTimeout(final Searchable searchable, int delay) {
        final Timer timer = new Timer(delay, new ActionListener() {
                searchable.hidePopup();
        timer.setRepeats(false);
        searchable.addSearchableListener(new SearchableListener() {
            public void searchableEventFired(SearchableEvent e) {
                if(e.getID() == SearchableEvent.SEARCHABLE_END) {
                    timer.stop();
                else {
                    timer.restart();
Walter Laan
Postby JIDE Support » Wed Jan 26, 2011 10:54 am
Thanks for contributions. Will try to include your ideas into the open source project as long as it's unlocked.
Postby JIDE Support » Thu Mar 10, 2011 7:33 pm
Just so you know, Searchable#setPopupTimeout() is added in 2.11.2 just released.
Postby sbrattla » Tue Jun 21, 2011 1:17 am
That's great.
Thank you for taking suggestions into consideration. It's great to see a company being able to react fairly quick to improvement suggestions.
sbrattla
