by sbrattla » Tue Jan 25, 2011 7:55 am
When using the CheckBoxTree, I sometimes use the getCheckBoxTreeSelectionModel().setSelectionMode(TreeSelectionModel.SINGLE_TREE_SELECTION) to limit the
number of checked nodes. By setting it to SINGLE_TREE_SELECTION, only one node will be checked at any given time.
Is it possible to do this for the CheckBoxListWithSelectable too?
sbrattla
by JIDE Support » Tue Jan 25, 2011 10:50 am
I'm afraid not. As you can see in the javadoc, that's actually the major difference between those two classes. CheckBoxListWithSelectable is replaced by CheckBoxList intentionally.
Users browsing this forum: No registered users and 83 guests
