Disable checkbox in a CheckBoxTree
Postby hbrtest » Mon Jan 24, 2011 7:17 am
Hi Jidesoft,
I looked at the demo code, javadoc and at this forum but can't figure out how to disable a checkbox on a CheckBoxTree.
I created a CheckBoxTree and have the following DefaultTreeCellRenderer on it. I set the renderer using the method on CheckBoxTree. Most works as expected but the checkbox is NOT enabled. How do achieve that?
Thanks, Werner.
public class ImageLayerTypesListTreeCellRenderer extends DefaultTreeCellRenderer {
    private static final String MAP_LEGEND_IMAGE_PATH = "../maplegend/icon.%s.png";
    public Component getTreeCellRendererComponent(final JTree tree, final Object node, final boolean sel,
            final boolean expanded, final boolean isLeaf, final int row, final boolean hasFocus) {
        super.getTreeCellRendererComponent(tree, node, sel, expanded, isLeaf, row, hasFocus);
        if (isLeaf && ((DefaultMutableTreeNode) node).getUserObject() instanceof ImageLayerTypeModel) {
            ImageLayerTypeModel model = (ImageLayerTypeModel) ((DefaultMutableTreeNode) node).getUserObject();
            final ImageIcon image = ImageUtilities.loadImageIcon(String.format(MAP_LEGEND_IMAGE_PATH,
        model.getImageLayerType().name()), false);
            setIcon(image);
            setText(model.getImageLayerType().getFullName());
            if(!model.isEnabled()) {
               setEnabled(false);
               setForeground(Color.gray);
        return this;
hbrtest
Re: Disable checkbox in a CheckBoxTree
Postby JIDE Support » Mon Jan 24, 2011 11:48 am
Please override CheckBoxTree#isCheckBoxEnabled(TreePath) to disable the specific node.
Postby hbrtest » Tue Jan 25, 2011 3:22 am
Thanks!
The checkboxes now appear disabled when I want them to. However, I also when setDigIn = false I am able to select a node.
Is that a bug? Please note that I use version 2.8.2.
hbrtest
Postby JIDE Support » Tue Jan 25, 2011 12:08 pm
Can you please elaborate your issue again? I don't think setDigIn(false) would block the customer to select a node. A test case would be highly appreciated.
