Build new CheckBoxTree based on selected nodes
Postby Born » Mon Dec 27, 2010 10:05 am
I'm trying to create a Dual List component but instead of lists I want to use CheckBoxTrees. So i want to build the right hand tree from the selected nodes of the left hand tree. The problem I have is: when all children of given parent node are selected getSelectionRows() and getSelectionPaths() return only the index or the path of the parent node and I have to do a lot of additional checks for each parent node and its selected children. Is there any elegant way, I can build my new tree based on the selected nodes of its ancestor and how can i get all children paths if they are all selected for current parent. Here is my code for the moment:
public void buildSelectedAccountsTree() {
       int[] treeRows = availableAccountsTree.getCheckBoxTreeSelectionModel().getSelectionRows();
       Arrays.sort(treeRows);
       DefaultMutableTreeNode rootNode = new DefaultMutableTreeNode(availableAccountsTree.getModel().getRoot());
       HashMap<DefaultMutableTreeNode, DefaultMutableTreeNode> nodeMap = new HashMap<DefaultMutableTreeNode, DefaultMutableTreeNode>();
       for(int i = 0; i < treeRows.length; i++) {
          DefaultMutableTreeNode lastNode = rootNode;
          TreePath treePath = availableAccountsTree.getPathForRow(treeRows[i]);
         Object[] nodes = treePath.getPath();
         for (int j = 1; j <= nodes.length-1; j++) {
            DefaultMutableTreeNode node = (DefaultMutableTreeNode)nodes[j]; //first node is always the root node, miss it
               if(nodeMap.get(node) == null) { //no such node, must make one
                  Account nodeAccount = (Account)node.getUserObject();
                   DefaultMutableTreeNode newNode = new DefaultMutableTreeNode(nodeAccount);
                   nodeMap.put(node, newNode);
                   lastNode.add(newNode);
                   lastNode = newNode;
               else { //already such node, just put it to be lastNode
                  lastNode = nodeMap.get(node);
Thanks in advance.
Born
Re: Build new CheckBoxTree based on selected nodes
Postby JIDE Support » Mon Dec 27, 2010 11:32 am
Please try to invoke CheckBoxTree#setDigIn(false). However, you will not be able to select the parent node to select all its descendant in this mode.
Postby Born » Mon Dec 27, 2010 1:17 pm
Hi again and thanks for the quick answer.
Yes i saw this method, but as you said I would not be able to select all parent's descendants and this is functionality i want to keep. So i guess i have to write a workaround code and manually check for this.
By the way, is this the desired behavior?
Regards.
Born
Postby JIDE Support » Mon Dec 27, 2010 1:32 pm
Yes, that is exactly what isDigIn() is designed for. Please use CheckBoxTree#getCheckBoxTreeSelectionModel()#isPathSelected() directly to check if the child path is selected. Please make sure the path you passed into that method is exactly the path the CheckBoxTree keeps.
Postby Born » Mon Dec 27, 2010 4:31 pm
Actually I meant getSelectionRows() and getSelectionPaths() behavior in case all children of given parent are selected.
Born
Postby JIDE Support » Mon Dec 27, 2010 8:34 pm
Yes. If the digIn flag is true, CheckBoxTreeSelectionModel#getSelectionRows()/getSelectionPaths() returns only the parent node although CheckBoxTreeSelectionModel#isPathSelected(theChildNode, true) would be able to return correct value. I'm afraid you would have to keep your work around code there to achieve your goal.
